Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
95 96 97 98 99 100 101 102 103 104
106 107 108 109 110 111 112 113 114 115
  1. sonickarma
    magnetic rf interference for non shielded devices , e.g. mobile phone and wifi interference
    I pressume?
  2. Mojo ideas
  3. mscott58
    3.5mm mono plugs on both ends, 75 Ohm coax cable between. Moon sells one. Cheers
  4. psikey
    I get none, sounds perfect just as it does out of JRiver on the laptop.  Never had any with the HA-2 or Dragonfly v1.2 either.
    The SE846's are very revealing so I'm sure I'd notice if there was any. What phone/IEMS's you using ? (don't get any with Samsung S6 either).
    If I plug my SE846's directly into a PC/laptop headphone out I can usually hear what your describing, sounds like echo pulses in a pattern sometimes. Surprisingly I get none on the XPS13 headphone out either but did with an MSI gaming laptop and on work desktop PC.
    Just been listening to various stuff at work for last 4hrs with everything from Jazz/Vocal/Classical/Pop/Rock and all sounds awesome with no fatigue at all (though the SE846 with Westone silicon grey Star tips are awesome comfy fit for me with excellent seal).
  5. Ike1985
    Interference seems troublesome, I wonder if some phones would be better than others? What about the aluminum block-it pocket things?
  6. sonickarma
    Maybe the case to be released can have magnetic shielding ?
  7. Rowethren
    I am using a Oneplus One with some Westone W60, using the star tips as well (red) they are the most comfortable tips I have used by far! I guess maybe the specific point the mojo is pressed against my phone could make a difference. I will test when I get home.
  8. mscott58
    Any chance the interference is impacted by the type of cable being used?
    I'll test it when I get mine, but I could see an improperly shield cable causing issues.
    Guess the best way to test this is to see if there's interference even when using Toslink.
    Cheers
  9. Mython Contributor
  10. mscott58
  11. Hachiko270296
    This thing confuses me. How can it drive the HD650/HD800 when it puts in under 100mw into 300ohm?
  12. doraymon
    Quick first audition of the Mojo today.
    I don't want to post any impressions on the sonic performance but can confirm that although much smaller than the Hugo, this is not going into my pocket together with my iPhone.
    Too bad because, as an enthusiastic Hugo owner, I'm pretty confident this will deliver similar "Chord pleasure".
  13. imattersuk
    How can you test a Toslink cable with a phone ?
  14. Rowethren
    Yeah basically, really is a horrible sound!
  15. mscott58
    I was thinking about having the Mojo hooked up to something with a Toslink output (like an AK) and then see if a phone near the Mojo had an impact. That way you could see if it was the Mojo itself or the cable.
    You are correct that it would be hard to find a smartphone with an optical output. That might be a bit of a unicorn?
    Cheers
