Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. UNOE
    I wish there was more dim levels as well even LED off.  The other thing I wish there was static line out.  Even detect the line out being used then change the single output to lineout voltage with ability to adjust it from there (instead of there being two headphone outs).  The problem I have with the way it is now.  Is if you activate line out and accidently touch one of the volume buttons (unknowingly). after you activated line out, then it remembers that position next time you turn it on.  You can blast your ears or even break your headphones if your not careful.  To make things worse.  The listening volume I usually use has a similar color to the line out color so I never know.  So what I end up doing it setting the volume to zero every time I turn it on just incase which I feel is a annoyance.
    Edit : Or they could of made it not remember any volume after the lineout was activated.  Or not remember any volume higher than 1.9.  But that would have issues with some power hungry headphones that are in that range.
  2. masterpfa
    Each to their own I guess.
    Personally prefer to hear my music at the Native Bit Rate, I cannot put my finger on what but never sounds right to my ears as Native does.
    [​IMG]
  3. music4mhell
    Will there be any difference, if we use 22 awg or 28 awg micro usb cable ?
  4. audi0nick128
  5. Mython Contributor
    That's because no-one can hide how 'brilliant' Mojo is! [​IMG]
    Xacxac and Peter Hyatt like this.
  6. jmills8
    Anybody here has the Onkyo dap and the Mojo?
  7. Satir
    n/a
  8. che15
    Can u please tell us how u like the sound signature of the QP1R, what does it do better than mojo.
    Thanks
  9. jmills8
    Isnt the sound coming from the Mojos Dac and not the dap?
  10. Satir
    n/a
  11. Carl6868
    Not if it isn't connected !
  12. jmills8
    Oo true missed that. So he is saying he prefers the sound from the dap than the Mojo.
  13. Duncan Moderator
    The QP1R sounds much more like a Hugo than a Mojo...
    It is down to personal preference - My personal stance is that I prefer the warmth of the Mojjo compared to the slightly clinical nature of the QP1R / Hugo...
    YMMV
    Hawaiibadboy and jmills8 like this.
  14. UNOE
    audi0nick128 likes this.
  15. Xacxac
    Haha true! Actually, sometimes I prefer the bright setting, as the left and right light leak to the middle ball on dim setting. For example, white(-) and red(44.1) yield to pink(+).
    Tried Hugo with the exact same result. Hugo's cleanliness detaches myself and the music. Doesn't mean Hugo is not a good product though.
