Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12473504
Post #15,213 of 40,385
Xacxac
GOOD HINT :
I am use my mojo with iphone(6s). Last evening i just download ONKYO player and turn ON it upsampling option.
Wow great !!!! I found that there were huge improvement in sound quality from my iphone +mojo+se846.Actually sound quality improved both flac and even 192 mp3 as well...
Then i google .. And try to find the reason. Then i found that its not new thing and most audiophiles use that technique to improve sound quality.
From theory i found that to get max sound quality you have to upsample integer multiple of original song sampling frequency. For example if you have cd ripped flacs sampling freq is 44.1 so you have to upsample it to 88.2 or 176.4 to get max sound quality.( actually ONKYO player do it automatically)
Hope this will help our friends!!!!!
Theoretical explanations can found here.
https://www.audioholics.com/audio-technologies/upsampling-vs-oversampling-for-digital-audio
http://www.mlssa.com/pdf/Upsampling-theory-rev-2.pdf
I would say you should definitely do whatever gives you the most pleasure
However, the designer of Mojo has discussed upsampling, previously, in the thread:
i dont believe up sampling will improve sound as the audio data wont change from the sampling method imo
I tried playing around Onkyo settings. Upsampling & PCM>DSD realtime conversion.
Upsampling (2n times): I noticed that the whole voicing becomes thinner. I definitely don't like the result. Please note that I believe this is just psychological.
PCM>DSD: Can't notice any difference.
In the end, I follow Rob advise. I don't think iPhone SOC can match Mojo FPGA in terms of covert & sample.
post-12473512
Post #15,214 of 40,385
sharon124
Yes correct real time dsd conversion for me also didnt provide proper results.
Just pcm upsample is enough.
post-12473559
Post #15,215 of 40,385
noobandroid
Malaysia
Malaysia
from android otg audio out up sample and by uapp otg out i didn't find any significant results either
android out is up sampled while uapp out by native sampling
post-12473636
Post #15,216 of 40,385
UNOE
Orange County, CA
Orange County, CA
Definitely have to give the JBLs a try.
What kind of cabling are you using?
I have a pretty Standart 3.5mm to Dual 6.3mm that would work, but would be interested in impressions with higher quality cables.
Cheers
I'm using this cable separated to each speaker.  http://www.monoprice.com/product?c_id=102&cp_id=10218&cs_id=1021815&p_id=5597&seq=1&format=2
Its a good gauged cable.
post-12473653
Post #15,217 of 40,385
SearchOfSub
I like the black CNC'ed aluminum. Reminds me of the faceplates of the old EAD and Theta units I have. I also like the ability to dim the lights of the Mojo. The highest settings are way too bright to be used in a dark environment but the lower setting is just right.
How to dim light on Mojo?
post-12473670
Post #15,219 of 40,385
jmills8
Previously known as bmiamihk
Hong Kong and Miami
Hong Kong and Miami
post-12473690
Post #15,220 of 40,385
Lohb
Surfing on electro waves....
Anyone using a tube amplifier after the magic MOJO with planars to add in some 'pleasing distortion' ?
I'm guessing the Project Ember 2 and MOJO may be a nice combo on older mastering
as well as the MOJO in vanilla direct mode to planars with more technical quality mastering.
post-12473691
Post #15,221 of 40,385
noobandroid
Malaysia
Malaysia
then what ? Lower the volume ?
that's for the dim light when after power on 2 vol led pressed
for 3vrms its 2 vol led pressed then power on
2 vrms is 2 steps down after the above process
Reactions: jmills8
post-12473696
Post #15,222 of 40,385
jmills8
Hong Kong and Miami
Hong Kong and Miami
I would like it dimmer.
post-12473710
Post #15,223 of 40,385
x RELIC x
The West Coast, Canada
4 clicks lower, not 2, and it's technically 1.9Vrms. :)
Reactions: jmills8
post-12473737
Post #15,225 of 40,385
jmills8
Hong Kong and Miami
Hong Kong and Miami
Users Who Are Viewing This Thread (Users: 3, Guests: 10)
