Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12467897
Post #15,031 of 40,442
Wyd4
Country Victoria, Australia
OK in what way or what sense is it not?
The ground/sense isn't shorted for one. Provided it's the cable chord supplied with the mojo.
But other than that why are we even arguing. If it works. Be happy. If someone else's works. Be happy for them.
Cmon bring it in. Group hugs
post-12467899
Post #15,032 of 40,442
harpo1
Does it matter guys?? Who cares, just enjoy your mojo!!!
Loving mine, with my X7 rooted. Finally have Moar bass!!
It matters because I'm sure there are plenty of people using the mojo that still run an older version of android on their phone.
post-12467906
Post #15,033 of 40,442
masterpfa
I was in the mood for that
What I could have said and what I should have said is the the supplied cable can be used to connect your Mojo with the adapted shown in the pictures and depending on your phone or device and Android version.
I made the assumption that the question was asked with regards to connecting the Mojo to a USB device and the above adapters work more than sufficiently depending on the connected phone/DAP.
But the inner voice won out that time (he's securely locked up again now)
post-12467909
Post #15,034 of 40,442
warrior1975
Indeed you are 100% correct, but those same people are highly unlikely to manage to read those few posts. How many times have certain things been explained here? Refer to page 3. The likelihood of someone finding those posts, mixed in with every other post... But you are correct,it does matter. But it's been pointed out, let's move on in the spirit of the great Mojo!!
post-12467915
Post #15,035 of 40,442
harpo1
Will do.
Reactions: warrior1975
post-12467919
Post #15,037 of 40,442
AC1
  Because an OTG cable is wired different.  If you phone is on Android 4.4.2 or later and supports USB audio an OTG cable is not required.
What changed in Android software or the usb port that allows detection of data (or does the Mojo send some signal)? Might of missed this on updates to Android. For using data sticks it still is mentioned that OTG cable is required.
post-12467947
Post #15,040 of 40,442
masterpfa
post-12467992
Post #15,042 of 40,442
Mediahound
USA
USA
Got my  Mojo delivered an hour back. It was exciting unboxing the same. Could someone tell me what amp Charger  I require to charge it. Can I use  a 2.1amp charger or do I need to charge it with 1 amp charger.
Yep, any usb charger higher 1A or higher is fine.
post-12468024
Post #15,043 of 40,442
jincuteguy
Well the new Samsung S7 Edge has Anddroid 6.0, and it doesn't work regular USB cable.
post-12468035
Post #15,044 of 40,442
warrior1975
Sammy is notorious for making life... Challenging. Are you certain it's not working?
post-12468046
Post #15,045 of 40,442
captblaze
Blazin it up in the land of Lincoln
One possible reason is that you need the USB audio 2.0 driver for OTG less transport and if memory serves me correctly Mojo only supports USB audio 1.0 hence the need for the OTG cable
Users Who Are Viewing This Thread (Users: 1, Guests: 17)
