Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
991 992 993 994 995 996 997 998 999 1000
1002 1003 1004 1005 1006 1007 1008 1009 1010 1011
  1. mrback
    Hi, many thanks for the shouts. I am using the L21 cable & the 3.5mm coaxial adaptor for the x3ii / x5ii. The one in the second pic.
  2. harpo1
    You need the one in the 3rd pic if you plan on using the L21 cable.
  3. mrback
    oh crap, really? why is the 3.5mm coaxial cable bundled in the box then? this is driving me nuts. Hope Vidal comes up with the goods tomoz. many thanks for all your help clarifying.
  4. harpo1
    Because you use it to connect to a normal digital coax cable.
  5. mrback
    I have to say the customer service from FiiO has been a bit poor here, I asked them what cables to use & they said the L21 will work with the cable that comes in the box with the X5ii to hook up to the mojo. They even sent me a pic! The cable in the third pic is for the original x3 & x5. well confusing.
  6. x RELIC x Contributor
    look carefully on the plug. The X5ii end needs to be like this.
    The mojo end needs to be like this.
    To use a cable without adapters you need to purchase one that is custom made because FiiO decided to share the coaxial and line-out jack.
    You can purchase one from Moon Audio:
    http://www.moon-audio.com/black-dragon-mini-coax-digital-cable-hifiman-player.html
    Or Custom cables UK:
    http://www.custom-cable.co.uk/custom-cable-cc35-3.5mm-coaxial-cable.html
    For both option you NEED TO CHOOSE YOUR DEVICE BEFORE ORDERING in the options drop down menus.
  7. jincuteguy
    What is the included USB cable for? Is it OTG? Or just a standard cable?
  8. masterpfa
    It is OTG
    Used for connecting to PC or, with the correct connection, to a mobile phone or USB DAC
  9. harpo1
    No it's not an OTG cable.
  10. warrior1975
    Listening to Norah Jones right now... That guitar... Jesus, sounds so damn good. Like it's here live. Too bad I don't know the sound do of other instruments too well, not big into concerts.
    X7-(coax)-Mojo-Fostex Th900=:grinning::grinning:
    chillaxing likes this.
  11. masterpfa
    Well considering I have got it to work between my Mojo and my Phones means it's doing a great impression of one
    [​IMG]
  12. RuFrost
    Guys can you tell me about comparison between Centrance mini-m8 and Mojo? direct me plz if thread or post already exist..
  13. harpo1
    The cable you have it connected to is the otg not the one supplied with the mojo.
  14. Carl6868
    How exactly is it connected ?
  15. captblaze
    mind me asking which phone is it that you have that accepts a USB A connector? mine only do micro b or usb c
