Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Jul 22, 2022 at 8:12 AM Post #5,071 of 5,535
dsrk
Hyderabad, India
Apologies if this has been asked before.
I want to give my Mojo2 a try via Innious Zen Mini Digital OPT out into Mojo2 and then 3.5mm out to 2 RCA cable into my Topping A90D.
Do I just set the Mojo2 to max volume and adjust the A90D volume to suit ?
You need to set the volume on Mojo 2 to Color Indigo anything above it starts to distort.
Jul 22, 2022 at 8:18 AM Post #5,072 of 5,535
dsrk
Hyderabad, India
From my Mojo 2 presentation:
So for 2v you need to set both volume LEDs to indigo (that's the first colour above blue).
Please find above Rob's post to achieve 2v output by setting the volume on Mojo 2 to Indigo.
Jul 22, 2022 at 11:35 AM Post #5,074 of 5,535
Chibs
Ontario
Once you're on high gain on the mojo, press the volume up button 41 times so it's @ the optimal voltage.
Jul 23, 2022 at 6:19 AM Post #5,078 of 5,535
Edyeded86
UK
Hi, silly question, have any one found sound changes while Mojo2 inside tight case?
let say, Dignis , Mitter etc.
I use the official chord leather case and never had an issue..
How does the sound change?
Is your mojo 2 running hot?
Jul 23, 2022 at 7:55 PM Post #5,079 of 5,535
chaotic_angel
Bali, Indonesia
Well in my experience with dignis case, sound less open than the non case usage 😆 nevermind tho this might just me.
Relatively hot
Jul 24, 2022 at 9:21 AM Post #5,081 of 5,535
Kentajalli
London
Relatively hot
Posts like this, give head-fi a name!
Jul 24, 2022 at 11:38 PM Post #5,083 of 5,535
Menkau-ra
USA
I bought mojo 1 on release. Pretty lame to know this doesn't support LDAC or any wireless solution without a bulky poly. I would have bought a second mojo if it was all wireless. Plus took way to long for mojo 2 to come out and not include wireless.
I agree, BT is absolutely must to have these days.
Jul 25, 2022 at 9:28 AM Post #5,085 of 5,535
Kentajalli
London
Chord Dacs are all about sound quality and not convenience.
Even LDAC degrades the sound noticeably.
Even the BT on Poly was an afterthought. the network side, is bit perfect!
If you need BT, choose something from ifi, much cheaper, smaller and on LDAC, probably same sound quality as any DAC. the BT is the bottleneck.
I used the BT on my Hugo2 once, to know I never need to do it again.
Same goes for BT LDAC on my Topping DX7 pro, it degrades the sound too much (for me).
