So what are you doing with your Hugo2?I see. I have the same issues with both the Mojo and Hugo 2. I was using the Hugo 2 as a desktop DAC, but then I got a TT2 and didn't need it for that anymore. The best use case was for travelling. I would connect to it via USB and then I could EQ with Equalizer APO. That's why I would love parametric EQ in the Mojo 2. I would buy that in a nanosecond at its current price if it had 12 band parametric EQ. The problem is to do it, you need a screen interface which Chord is not good at delivering on. I love the sound of the Hugo 2/2go, but it's just easier to use a DAP and so that is what I do now when not listening to my desktop.
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
I hope Chord takes the heavy feedback they‘ve received and introduces a non-Poly Gen 1 compatible version of the Mojo 2 with dual USB-C I/O. Its a simple problem to rework and would pave the way for a better, smaller Poly 2.
utdeep
- Oct 15, 2001
If they did, who would buy this version? They’re all in now. Just like they were with the Poly
If such a version existed today, I would order it. The Mojo 2 leaves a bit to be desired and if I wanted go back in time with old I/O, it almost makes more sense to buy a used Hugo 2. While the Mojo 2 may be backwards compatible with the Poly, its barely compatible with iOS and Android as evidenced by the firmware log…If they did, who would buy this version? They’re all in now. Just like they were with the Poly
Any guesses of Mojo 2 Vs Hugo 2? Care to speculate?hugo 1 is quite a bit better than the mojo 1. I had mojo, H1 and H2 all at the same time once...
my guess is that mojo 2 will be more technical than H1, but H1 will be warmer.
I prefer using the hugo rca outs adapted to a 4.4 output produced a bigger soundstage than through the 3.5
From the horse's mouth, the Hugo 2 is still superior.
https://www.head-fi.org/threads/watts-up.800264/post-16792503
@Rob Watts, why do you consider Hugo 2 to be superior? The added features in the Mojo 2 make it seem less of an upgrade.
Any chance of a separate thread about why USB-C is essential in all gadgets for the USB-C evangelists? It's quite annoying for those of us who prioritise other things above that
I'm very excited for mine to arrive tomorrow and kudos to chord for a smooth release (at least in the UK) with stock available next-day. I remember the poly release had a several month waitlist which was painful and was preparing for the same.
@Rob Watts, do you consider Hugo 2 to be superior? The added features in the Mojo 2 make it seem less of an upgrade.
Did you mean to ask "Why do you consider Hugo 2 to be superior?" Because my post directly above yours gives you a link to where Rob Watts himself stated, today, that the Hugo 2 is superior.
I didn't see your post.Did you mean to ask "Why do you consider Hugo 2 to be superior?" Because my post directly above yours gives you a link to where Rob Watts himself stated, today, that the Hugo 2 is superior.
shootertwist
- Sep 6, 2010
That micro usb charging is a deal breaker for me… would have been nice if the usb c could be used for charging. I no longer have a chord mojo but i remember owning it twice in the last 6-7yrs and really liked its sound. The second time i owned it was when i went all in with the mojo-poly combination and sound wise it was great. I even managed to overcome poly’s cumbersome setup and made it work…
But back to that micro usb charging, what makes this worse is that if chord follows a similar pattern of upgrades, you will be stuck with this micro usb for the next 6-7yrs. My devices are all usb-c now with the exception of the iphone 13 pro max hence i am also one of those disappointed chord went with this old connector… but i guess i saved anyway so its a good thing. Like the others, the chord mojo 2 was a sure buy for me as i enjoyed the mojo 1… until i saw that connector.
rhart00
- Nov 25, 2011
Took the words out of my mouth.That micro usb charging is a deal breaker for me… would have been nice if the usb c could be used for charging. I no longer have a chord mojo but i remember owning it twice in the last 6-7yrs and really liked its sound. The second time i owned it was when i went all in with the mojo-poly combination and sound wise it was great. I even managed to overcome poly’s cumbersome setup and made it work…
GiullianSN
That was me…Like the others, the chord mojo 2 was a sure buy for me as i enjoyed the mojo 1… until i saw that connector.
I made a comment “this may be the Mojo I was waiting for.” Than had to edit my post after seeing the connector.
Charge and data on the same connector is not good for sound, so I wouldn’t expect them to use the new USB C for charging. I was expecting to have all connectors replaced by USB C in prepararion for also a new Poly with less troublesome setup.
GreenBow
- Feb 6, 2015
I don't really have any issues with the micro-USB. It's fiddly to get the cable in but that is all. Just have to concentrate and be careful.
USB-C would be very nice, but it's not a deal breaker in any regard.
However I got the impression from someone's post that USB-C would be able to charge faster. After googling, I read that the max current across micro-usb is 1A. That explains why when using a 2A charger I meansured the same current as a 1A charger.
I guess it's a downside though if Chord's DACs could charge faster using USB-C. Four hours charging is somewhat a drag. However it never really gets in the way for me. If I am using Hugo 2 and it runs out of battery, I can charge and play for a while. Or switch to Mojo.
Chord DAC batteries taking four hours to charge has never really been a problem. Although it would be nice if they charged in half the time. It would for sure improve the user-experience.
Having said all that, it depends also on the charge rate of the battery.
jlbrach
- Jun 4, 2005
I certainly wouldnt buy or not buy a mojo 2 over usb-c or micro-usb....
