lurk
- Jan 11, 2015
Noob question here. Would I be double amping if I were to plug the below?
Pc>usb>hugo>3.5mm>aego M 2.1
Are you talking using a headphone out? I believe that would be double amping. Would you want to just use RCA cables and use Hugo as a DAC?
So, about a week ago I bought myself a (2nd hands) Hugo* and I must say I'm deeply impressed with it's performance. Almost every iem/headphone I have scaled up in an impressive way.
Hi @Kerouac, good to see you like the Hugo. I have a few questions: Do you hear any differences between the coaxial out of the DX90 and the X5? If you do, what are they? Also, is that coaxial cable you're using there the one that comes with your iBasso?
Thank you.
Well, so far I've mainly used it with the DX90. But when I tried the X5 I think the sq was about the same, not totally sure on that though => will try that again later on this weekend. From a technical pov: shouldn't it be exactly the same as both daps are just transport when connected through coax?
Yes, the coaxial cable came with the DX90 and works fine imo...I'm also wondering if an upgrade coaxial cable would make a big difference (maybe less jitter => better sq). Curious about that myself => maybe another member out here knows and can advise on that?
Hi guys,different transports or drives do make a difference . I've got 2 cd player's,1 cd transport,2 blue ray players,1 laptop,and they all sound different,the best 2 being the cd transport by a long way with the Hugo.I also find optical sounds alot better than coax(more natural)I'd say.IIRC Chord has stated that the Hugo be immune to jitter, so different drives should make no difference. I haven't systematically compared it myself (FiiO X5 via coax and computer via Toslink), but heard and expect there to be no difference.
Interesting! I experienced sonic differences among different DC transports in the past (with the Bel Canto DAC2), but so far only heard a difference between USB and Toslink with the computer as source with the Hugo. The sound from the FiiO X5's coax is very good, actually excellent, certainly good enough to my ears. I can't compare it with the McCormack UDP-1 (universal player) because I use and need the X5's equalizer.
