Klonk
- Jun 16, 2008
Thank you Linntroika and PhilW.
Here's a question for the amazing Rob ...
Or should I just always use the hi-res input?
The "low-res" USB input was meant for compatibility issues with phones and equipment not able to work in hi-res. If your "low-res" music and setup work fine into the hi-res USB input, you should definitely just use that. I never use the standard USB input for anything.
Are you sure you're right in saying that you should always use the hi-res USB input?
Rob Watts has just said in answering my post that it is better to use a galvanic isolator such as the Olimex because of ground plane issues, and it is only possibly to use a galvanic isolator with the standard USB input. I take that to mean it's best to use the standard USB input and a galvanic isolator for upto 24/48 material, and only use the hi-res input when necessary for 24/96 and up. Maybe I misunderstood Robs answer. Or do you know of a galvanic isolator that will work on the hi-res input?
hmmm, I just ordered Olimex USB-ISO.
Can anyone confirm if it works with hi-res?
No it only works with the SD USB.
Rob
Too bad. I love the sound I'm getting from my MBP but when I hook Hugo up with my old beat-up Samsung S3, the sound is cleaner and improved sound stage.
Will disconnecting the charger from both Hugo and MBP reduce ground noise? I do hear slight improvement but I could just be imagining things...
