Chord Hugo
post-10249555
Post #196 of 15,544
barbes
for those thinking of pairing the Hugo with the Sony ZX1... Chord supply the required USB lead with the Hugo that works in conjunction with the Sony USB-Adapter...
Is that cable something other than a standard USB cable?
post-10249596
Post #197 of 15,544
zachchen1996
  Large-margin better.  I've heard M8/Apex Glacier/Vorzuge Pure - all very, very good - and the Hugo's in a different league.
so you did hugo to headphone vs hugo line out to amp to headphone? Because if you used those other amps with sources other than the hugo, then the comparison is invalid.
post-10249602
Post #198 of 15,544
OK-Guy
Kent, England.
Kent, England.
no... the Sony has a special USB adapter and I was asked if it needed a special USB lead (it doesn't)... it should be ok to use with other Walkman's via the WM-Port/USB adapter which could be a absolute boon... how's the Hugo sound with Red-book files? (I kinda know the answer but it's good to talk)
post-10249631
Post #199 of 15,544
Goldlion973
  This would never fit in a pocket (not mine, anyway).  This is in your briefcase/bag transportable territory.
I don't think even a lower-profile option, like Hugo/Touch, would work in an ordinary pocket - cargo pants, maybe, but not business wear.
Thought so.... looks wide, is it heavy?
post-10249640
Post #200 of 15,544
zachchen1996
it would also be interesting to find out which digital input on the hugo sounds the best, usb, optical, or coax. I have a feeling it would be coax
post-10249677
Post #201 of 15,544
rudi0504
I am agree with you
In home and portable : coax has the best sound quality
post-10249715
Post #202 of 15,544
jamato8
I have a feeling this will all filter out with time. The best digital input, best combination and it is all looking good.
post-10249889
Post #203 of 15,544
barbes
No, you're right, I misread the question.  Can't comment on amp alone or DAC alone.  The pairing is phenomenal.
post-10249896
Post #204 of 15,544
barbes
Not at all, just a bit bulky for being genuinely portable (vs. transportable)/pocket-friendly.  I don't consider the M8 "portable" either - this is about the same.  They're both fine to slip in a bag or briefcase, that kind of thing.
Reactions: Goldlion973
post-10250272
Post #205 of 15,544
alcyst
I'm posting this here, it may be an issue with the DAP, but I'll try everything.
I've had my AK100 for a while, but only tried to play 24/176 & 24/192 tracks through the optical output into my Hugo today. And nothing. Lower rate files play fine through the optical-Hugo chain. Everything sounds fine through the headphone output so the AK100 is accessing & playing the files.
Am I missing something basic?
post-10250332
Post #206 of 15,544
bmichels
France, Belgium and Morocco
there are some bugs in the way  AK100 handle somes resolution through the optical out.  I have experienced the following with my RWAK100 + RWA Bellina DAC:
If I play a  24/192 file, it play correctly  (which is different from your problem), but then it is unable to play a 16 bits file as the "next file".  I need to play a 24/96 file to get the AK100 down from 24/192.  It is crazy, but it is like it could not "Jump" directly from 24/192 down to 16 bits without an intermediate step at 24/96.   I reported the bug to Vinnie who confirmed it.
This is not exactly your situation, but may ring you some bels
post-10250890
Post #207 of 15,544
evolutionx
Singapore
Singapore
Thank you very much for doing this test for me.  I understand what you mean about "slam & details", but... did't you miss a little the "warm tube" sound of the TU-05 ?
-  Does this mean that you will not use the TU-05 anymore ? Or are there still some situation where you will use the TU-05 instead of the HUGO ?
- And what is your feeling about the built in "Crossfeed filter" or DSP.... whatever they call it ?
You are welcome.  I enjoy playing with all these gears.    As long as pairing with TH900, I think i will stick to Hugo for sure.   The synergy is amazing with TH900.    The cross feed filter does make some difference, but not significant in my opinion.   Very much like the filters on Audiolab MDAC.
post-10251403
Post #208 of 15,544
The greater the stereo separation, the more exaggerated the left-right panning, the more pronounced the effect of crossfeed will be.
Try some old stereo Beatles with all-the-way-left and all-the-way-right images in the mix, and the effect of switching crossfeed on is dramatic. A good example track that I usually use crossfeed with (if I have crossfeed available) is "Change" by Blind Melon--play it with headphones on, and you'll immediately know why. (By the way, without crossfeed on, it's fun to shift balance all the way left and listen to Shannon Hoon a capella for the better part of the first minute of the song.)
post-10251485
Post #209 of 15,544
bmichels
Thanks...  So I may go for the HOGO and...save some $ by avoiding the AK240 :)
But then I need a decent source for the HUGO, and I am feed-up with the shrinked AK100's screen and poor UI & Playlists....   --> Android + USBAP  ? iPAD ? ...
post-10251607
Post #210 of 15,544
CosmicHolyGhost
Exhaustively burning holes in his wallet
Thanks Jude for explaining the crossfeed filtering function.
I feel it will be useful for listening to old jazz recordings in current stereo mix which the panning becomes too pronounced/unnatura on HD800. I pretty much prefer the original mono recordings if available when listening on headphones.
