I use a Uptone USB adapter, it sounds fantastic, but it is very short and I need more space for the ethernet connection and the BNC is in the way
Chord Electronics Qutest DAC - Official Thread
- Thread starter ChordElectronics
IAIA
Is there a consensus on the use of conditioners such as SOtM tx-USBultra or iPurifier, as well as Rendu and SOtM streamers with Qutest? At the moment, I just have a laptop with Fidelizer and Audirvana, I'm happy with the sound, but maybe there is room for improvement?
Oh yes there is especially when using a ‘normal’ computer. I don’t have any more my Qutest but I still keep my uRendu. It really makes a difference.
It seems that there is a consensus with the others. You could also try an Isoregen. Not so good but it’s much less expensive. Use the uRendu with a good LPS. I use an sbooster but a LPS 1.2 it’s also fantastic. If you are short of money try to get an used package (uR + LPS). Finally if I may advice get a second hand Cisco 2960 switch. They can be find between 20 to 60 dólares. New were more than 600. If you want to improve use an optical module to the Cisco or even better between the Cisco and the uR. A good power supply will also make a difference. I started with a Jameco (10 $). Much better than the one included. Looking forward to receiving my etherregen... Good luck
IAIA
Thanks for the answer. I forgot to mention that I don’t need network functions at all, I like my laptop and I’m only ready to consider buying network devices if it gives significant growth in SQ.
Battery powered both, good enough.
It will improve SQ if you use streaming services and probably if you also use cd files with an additional computer or a NAS.
I never tried a battery with a Qutest, so I can’t comment. Used one (don’t remember the name) with my sonictransporter and I prefered the HDPLEX I’ve been using. Ultimately it will depend on the system you’re using and also the quality of the battery. Cheers
IAIA
I use high quality cd-rips streaming from my external hard drive. My question is: Is a regular laptop inferior in sound quality than network devices? My system is pretty revelatory: Dynaudio Special 40 + Perreuax pre amp + Perreuax power amp.
Also, what is general agreement on the use of conditioners like IFI products?
Sorry for not being sufficiently clear. I was not saying that network devices are superior to computers. I suggested that using a NAS or an additional computer might (and I say might) get you a better sound when using a good switch. The connection being by Ethernet, of course. I am saying this because I prefer the sound coming from my Zen MK III and my sonic transporter connected through my Cisco to the ultra rendu than connected directly to the uR. Turning to the starting point and from my experience what I am certain is that using a USB ‘reclocker’ improves substantially the SQ coming from a computer. Even a Zen MKIII. Best, Jorge
IAIA
OK, got it, thank you!
IAIA
Has anybody had positive effect using Qutest with iPurifier 3?
Did you have good results with iPurifier 3?[/QUOTE]To my surprise the iFi iPurifier 3 improved clarity a lot with the 2Qute. Soon I will be able to test it with the Qutest. I am not expecting it to make as big of a difference as it does with the 2Qute but we shall see.
I've got the Pro iDSD here on loan, and it's DAC performance is absolutely impressive. It just controls the low-end so much better than 2Qute. It is also less bright and more dynamic. I just can't really go back to my 2Qute after the iDSD but I also can't afford to buy the iDSD and I wouldn't use 80% of its features anyway.
I really hope the Qutest will cure my issues and bring a slightly less bright sound but a more firm and confident low-end control versus 2Qute. I will report back in a few days.
Sold it after buying the Qutest. Didn't need it anymore.
IAIA
[/QUOTE]
Sold it after buying the Qutest. Didn't need it anymore.[/QUOTE]
Are you using PC?
Are you using PC?
For PC use this one with external power supply like, for example, Sbooster 5V:
https://jcat.eu/product/usb-card-femto/
Solved my problem for good.
IAIA
I use a laptop.
I use a laptop.
Then ISO Regen might be OK for you. I tried ISO Regen, iUSB3.0 nano and then JCAT. At the moment I use JCAT. ISO Regen was better for me than the iFi solution.
Total: 9 (members: 0, guests: 9)
