Chord Electronics Qutest DAC - Official Thread
275 276 277 278 279 280 281 282 283 284
286 287 288 289 290 291 292 293 294 295
  1. GreenBow
    Yes Qutest is fine for gaming, and there is no delay. I have used Mojo, Qutest, and Hugo 2 for gaming. Qutest rocks for gaming by the way. Gun sounds the whole deal all sound brilliant on the Qutest. The clarity does a lot for making outdoor scenes feel like you are in fresh air. Compared to my Meridian Explorer which sounded a bit muggy.
    AC-12 likes this.
  2. Reactcore
    The delay isnt much. Have compared with my Questyle DAC (which has a AKM chip) and with direct AB test with a switch i dont notice it. I also watched movies with it with lipsync replay (on Jriver)
  3. blueninjasix
    I've followed the general consensus on here and switched over from usb to optical input on my Qutest. I bought a QED glass cable thinking I could take advantage of the 192KHz capabilities. I am shocked to discover that despite my computer being able to transmit a 192KHz file, Qutest's optical input maxes out at 96KHz. Even Dave has the same limitation but TT² can manage 192KHz that matches the cable. I'm disappointed.
  4. Victorr
    I had experience when a branded optical cable did not pass 176.4 and 192 kHz, and the Chinese noname worked without problems.
    blueninjasix likes this.
  5. dinus777
    I'm running Qutest optical connection 24bit 192Khz without a problem with sysconcept.ca cable and mac mini late 2014.
    Chord Qutest manual also says that it is capable 24bit 192Khz or DSD64 via Optical. Check you cable or pc/transport....
    blueninjasix and Paul Bjernklo like this.
  6. blueninjasix
    That's interesting. I didn't check the card that came with the unit, I checked online here on the features tab which states maximum input on the green optical input as 24/96 https://chordelectronics.co.uk/product/qutest/
    However, further down the page, there is an icon depicting optical input at 192KHz. I have contacted Chord to seek clarification.
  7. GreenBow
    As folk have said, it might be your cable. The same happened in the Mojo thread. Folk had to buy a cable that could pass 192KHz.
  8. blueninjasix
    That was my initial thought too as the cable is QED Reference Optical Quartz which is specified at 192KHz. I have started a returns procedure with QED but they asked me to check with the manufacturers of the equipment at each end of their cable and it is Chord that is causing doubt due to the apparent contradiction of specs on their website.
  9. MagnusH
    I have an RME ADI-2 DAC and not a Qutest, but for me it was a cable issue. Bought a Lifatec glass cable and its rock solid at 192khz. (1.5 meter long), but naturally the sender has to support 192khz as well.
  10. GreenBow
    Well, on the Mojo thread it was a case that some folk had cheap optical cables. All this happened ages ago - years. Then after buying a quality optical cable all was fixed.
    However, I just checked my Qutest and a 192KHz file for you. I am playing Qutest now with an optical cable that I bought from Amazon for about £5. It's running 192KHz perfectly.
    Another suggestion would be check your playback file source, and the software running music. Sometimes output an output channel is capped on the device.
    I once could not understand why my music always played at 44.1KHz, and found a setting in my music player. Then another time I got a blue light (192KHz) on my DAC not matter what. It was a Windows setting that fixed that.
    It seems your cable is good to go.
  11. blueninjasix
    I'm using the Topping D10 as a USB to optical interface and the topping is good to go at 192KHz per its website: Screenshot_20190927-224517.png
  12. GreenBow
    Sorry but I don't know that device. I would take it out of the chain until you can determine if the Qutest is performing right with your cable. I would go straight from file-source to Qutest via optical if your file source can do that. (Like if you are using a laptop with an optical output.)
  13. GreenBow
    Pretty sure I have heard that said on the rare occasion before. I was very surprised when I got my cheapo optical cable, that it ran 192KHz.
  14. blueninjasix
    I get the same result with my ASUS Xonar SE soundcard which also has 192KHz capability.
    I use Foobar 2000 Wasapi push which doesn't require me to specify a frequency I think?
    I would be 100% convinced that the cable is faulty if I could be 100% sure of the Qutest's specs. My only doubt with Qutest is the apparent conflict on Chord's own website. I really appreciate your help in trying to resolve this issue for me.
  15. GreenBow
    I would definitely check Foobar settings. Like once I found that the default setting for JRiver set everything to 44.1KHz. I had to change that to 'no change' for files of different sampling frequencies.
    I am telling you the truth that the Qutest plays 192KHz. However if you are still sceptical, then you will have to wait for other people to confirm it for you.
    I have taken a photo of Qutest playing 192KHz with the blue sampling frequency light. However my camera is old and not brilliant. (I know, I need a new one. Just choosing does my head in.) You can still just see the sampling frequency light is blue though. Photo taken in low light, otherwise flash would kill the blue light. Plus the input is green for optical, (as well as the voltage output at 2V green).
    You should tell Chord about the wrong information on the website. I am sure they would assure you of the specs of the Qutest. Also they would be grateful for your notifying them of the wrong data on their website.
    It's also obvious that the Qutest does 192KHz on optical, because it has the same DAC parts as the Hugo 2.
    I don't know why, but it's very difficult to capture the blue light with my old camera. This photo shows the blue light reflected in the port glass.
