Chord Electronics Qutest DAC - Official Thread
post-15047380
Post #4,021 of 5,014
Thank you,but I think I didn't explain correctly.
The Playstation will be connected via BNC to Qutest.Will this connection affect the sound from my CD transport when I listen to it(connected through optical)?I mean,will it add grounding noise to my optical input?
It depends upon the optical to coax adaptor - if it's battery powered, I wouldn't worry. A mains powered device will set-up ground loops via the PSU and so could have an influence on your overall RF noise levels, thus making it brighter than it should be.
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
post-15047388
Post #4,022 of 5,014
Zzt231gr
Greece
Greece
Thank you,sir!
I imagined something like this...It is mains powered.I will disconnect it when I won't be using it for the peace of mind and all will be well!
post-15048355
Post #4,023 of 5,014
Paul Bjernklo
London, UK
London, UK
Thank you,sir!
Deleted previous comment, yes I think you are correct that if you disconnect the converter from the mains then there will be no ground loop, but others can confirm or clarify.
Reactions: Zzt231gr
post-15048774
Post #4,024 of 5,014
jwbrent
California
California
I know there’s a battery pack that Rob recommends, but has anyone tried others such as Anker, and if so, how did you like the sound?
Reactions: Zzt231gr
post-15057360
Post #4,025 of 5,014
linearly
Hello, long time forum lurker here, decided to break the ice and make my first post.
In the past I've owned Mojo, Hugo 2 and DAVE, now recently got Qutest. I'm very happy with it, but was wondering on what would be the best input, USB or Optical. I see most prefer optical and maybe someone has experience with more expensive USB cables. I have a Audioquest Diamond USB from DAVE days and comparing it with the optical cable from Hugo 2 there is no contest really. Sure optical sounds darker, but the magic from the music is gone. With the AQ cable you can 'feel' the music, its like you are there, everything is more tangible, with no hint of harshness or digital glare. So the question is will a better optical cable surpass the AQ USB? Was thinking about Audioquest Diamond Optical, has anyone tried it against other glass optical? With Hugo 2 I've tried a glass cable and it was so much worse then stock optical, with a lot of harshness added, no clue how that's even possible.
Also I see many prefer to power the Qutest with a battery. I guess it depends, but for me doing that was so much worse then stock psu. It sounded so much brighter, really couldn't even listen more then 10 minutes. Someone here in this thread said that batteries would be worse since they are made to charge our devices not power high end audio gear and will introduce more noise, I guess he was on to something. For me Qutest sounds best now directly powered from PC's USB 3.0 port.
post-15058079
Post #4,026 of 5,014
GreenBow
Please does anyone know how many amps the Qutest requires at 5V. The supplied charger is the same as the Hugo 2 charger and provides 2.1A. (Cover charging and playing.) Would the charger that I used with Mojo at 1A be enough. Just in case one day, if the Qutest charger failed.
Reactions: Zzt231gr
post-15058094
Post #4,027 of 5,014
GreenBow
Toslink cables causes different amount of jitter, and no DAC removes all jitter, only lessens the effect. So even with a Chord DAC you get some benefit from a better toslink cable.
On USB Chord DACs send for data asynchronously, with an accurate clock. Then when all the samples arrive at the DAC they are clocked, which negates an jitter caused by cables. How jitter-free samples are, played with Chord DACs is therefore down to how accurate their clock is. There is no induced jitter in playback, due to data transference. The system is called iso-asynchronous. (Coaxial and optical are simply clocked.)
post-15058312
Post #4,028 of 5,014
GreenBow
I just measured current use of the Qutest.
In idle state it uses just over half an amp. (Something like 0.52A.) When playing music and a 192KHz file it pushed towards 0.6A. Similarly with 44.1KHz files. I found it also used more current when the music got louder. However the current increase was only small. In the few tests I ran, I never saw 0.6A fully; it was only as much as 0.59 etc amps. I drove it with a bit of 44.1KHz Def Leppard to get some peak power usage.
5V x 0.6A = 3W
(Side Note. Needing more current when music gets louder is the purpose of the supercaps in the TT2. When peaks currents are needed there is fast access power on tap. Hence why TT series would be more dynamic. Everyone probably already knows this, but I am just thinking out loud.)
I recall now that Rob Watts at some point mentioned that it's OK to leave the Qutest on. That being based on the minimal amount of power it uses. I am sure he mentioned figures of only 3W, but best check that. (I am going by vague memory here.) Personally I prefer to turn off Qutest over night. (Fire precaution. Although I doubt the Qutest could cause a fire.)
I do wish there was an off button though. I wonder about how it affects components when pulling power. Going by PCs can get damaged doing that. Although I am fully sure that it's safe to power Qutest like this. When I think how the Hugo 2 powers off, it's pretty much the same. Hold power button, and after a couple of seconds Hugo 2 shuts straight off.
post-15059488
Post #4,029 of 5,014
Deftone
UK
UK
I am going to be doing some more testing with optical vs usb, keeping it simple, both cables cost under £7.
Whether it is fake detail and transparency from noise or not some people seem to quite like it with usb.
Reactions: linearly
post-15059925
Post #4,030 of 5,014
linearly
5V x 0.6A = 3W
I really like the convenience of powering Qutest from PC's USB 3.0 port, less clutter and don't have to worry about powering it on/off. For me it doesn't really sound different vs. stock psu, also have a Jitterbug added to the power cable.
Thank you for the measurments, was a bit worried it will affect the sound somehow since the psu is 5v 2amps and pc usb is rated 5v 0.9amps.
post-15059942
Post #4,031 of 5,014
linearly
I've found another optical cable in my unused cables bin and did further testing. Its a Wireworld Nova Toslink and compared with stock optical from Hugo2 there are big differences. Not sure why, since both are acrylic, maybe the polished ends or number of strands who knows, but with the WW the veil lifted and the sound is so much better.
Now comparing WW optical with AQ Diamond USB, the differences are still there, but its hard to decide what cable I like more. Optical is more laid back, USB is more energetic, the details are about the same, the voices are more lifelike on the optical. I think I prefer the Nova optical vs usb for now. Can't imagine what a good glass toslink will do, if it sounds tiny bit better vs usb with a plastic one.
Will get the AQ Diamond Optical in the future, I'm sure it will surpass usb. As always my findings don't have to be the same for everyone, it depends on the system, how noisy the PC is, the house's power, the optical source etc. So what works for me doesn't have to work for everybody.
post-15059963
Post #4,032 of 5,014
Zzt231gr
Greece
Greece
I recently purchased the Lifatec optical and it is excellent!
post-15060191
Post #4,033 of 5,014
Doom0
Currently I have Chord Qutest and Gumby with me. So I thought of spending this beautiful and sunny Saturday afternoon in Long Island within the comfort of my bedroom comparing the DACs ,I mean thats what an audiophile is supposed to do in a sunny afternoon. I am using HD800s and 600 to compare and will first use Valhalla 2 and then LP with sys as switch box. I am not sure how to volume match both as I am using 2v out and I guess that should help me to do have same volume. Based on initial impression, I feel Gumby pushes the stage little back and Qutest brings things more upfront and Valhalla2 as dry treble and Gumby is taking the leading edge off which may and may not be good thing based on headhone and amp one has. Will report back later however I am not a technical audiophile so my comparison will miss words like transient etc, it will be in words of layman audiophile.
PS: I own both and so I feel I will not have any bias but I will leave that for self discovery.
I was browsing this thread but I did not see you reporting back as your promised. But looking at your current signature, it seems like you preferred Gumby over Qutest after all.
post-15060259
Post #4,034 of 5,014
kumar402
NY
NY
Ya I ended up keeping Gumby but to be quite honest it’s just preference. Here is what I posted in Gumby thread
“I like the denser tonality in vocals in Gumby. In contrast Qutest has the extension in the vocals but the way Gumby rounds off the vocals gives it a nice denser tonality.
Also I am enjoying the holographic soundstage, it fills the big cups of empyrean with sound and it engulfs you. It’s a nice experience.The stage seems pushed back compared to Qutest which has more upfront staging. The layering and separation is fantastic in Gumby. Although Gumby gives that 3D soundstage , I feel Qutest has bit more depth due to more extension in treble?
I feel better micro dynamics in Gumby as I can hear instruments at different level within a passage of play. However if you are fan of details Qutest pulls ahead as every little detail of music pops up at you but is it at the cost of dynamics, I am not sure? However I wouldn’t say I missed any detail in Gumby it’s just that every background instrument seems louder and easier to pick on in Qutest. Also with my listening level I didn’t find any difference in black background of Gumby and Qutest. Both are dead silent”
Most of the amp that I have or is in preorder stage are balanced and that also tilted the favor towards Gumby. Form factor wise Gumby is quite big and heavy. Almost 11Lb
Reactions: Doom0
post-15060873
Post #4,035 of 5,014
GreenBow
When I put a Jitterbug on the USB with Mojo I found it changed the sound. It needs noise removal, just the same as how you have your power cable set up. Noise gets into the analogue parts of the DAC and causes brightness.
I have Jitterbugs by default now.
Having said that though, Rob Watts put noise filtering on the USB input of the Hugo 2. I still have a Jitterbug in place when I use Hugo 2 from PC though.
Reactions: linearly
Users Who Are Viewing This Thread (Users: 3, Guests: 10)
