Chord Electronics Qutest DAC - Official Thread
post-14976296
Post #3,887 of 5,014
kerisabe
Studio
Studio
Website
www.chrisbunjamin.com
Btw I have a question regarding streaming quality using macbook pro running audirvana. Would the quality of streaming be better if the macbook pro is connected through ethernet cable to an airport express extender? Main airport extreme router is in another room. I use a small airport express to a wall plug which runs the ethernet cable to the mbp. Running optical to cut the noise.
post-14976304
Post #3,888 of 5,014
MagnusH
SWEDEN
SWEDEN
Thanks. Well mine will do 24/192 no issues, so is all good.
Just that some folk say they hear differences between different toslink cables and I don't get why that should be the case.
The reason toslink cables can sound different is because of different amount of jitter that they introduce. Jitter is a time-slot error, simplified: all the bits get there as they should, but not exactly when they should.
I experienced a little smoother higher frequencies with my Lifatec, but the difference wasn't huge. Note that this depends on the DAC as well, and its ability to handle jitter (basically reclock the signal). I have the RME ADI-2 DAC.
post-14976314
Post #3,889 of 5,014
Qute Beats
UK
UK
Website
www.last.fm
Thanks for that. Sure I can buy the difference in jitter on the cable being a factor with some DACs and would expect glass to be a better light transmitter, but Rob Watts' designs are jitter free AFAIK, though folk claim a difference with their Qutest. Just trying to understand.
Reactions: Baten and Zzt231gr
post-14976553
Post #3,890 of 5,014
MagnusH
SWEDEN
SWEDEN
I don't think any DAC is totally free of jitter (for any input), but some DACs are better at handling it than others. I think @Rob Watts puts on his "salesmen-cap" from time to time :)
post-14976921
Post #3,892 of 5,014
Deftone
UK
UK
The Chord measurements show impressive jitter suppression just like RME.
post-14977196
Post #3,893 of 5,014
Hmm - the facts are that you can put 2uS of 1kHz jitter on my DACs via SPDIF and can measure absolutely nothing, down to a FFT noise floor of -180dB. 2uS is a thousand times larger than jitter you would normally encounter on SPDIF.
I don't have a "salesmen-cap". Can you buy one on Amazon?
I am a measurement/objective listening based designer, and am driven entirely upon measurements and carefully controlled listening tests. If I can or can't hear a difference, I post on that. If I measure or can't measure a difference, I post on that. And if I find an observation that contradicts things I have posted before, I post that too. Moreover, Head-Fi posts from people using my designs has been incredibly useful in the past, as people finding sensitivities (X sounds different due to Y and Z), and this has allowed me to investigate issues because of these sensitivities - which then results in better performance from new designs - and I post on that too. But source jitter is for sure not one of these issues.
As a scientist/design engineer I deal in realities, and am solely driven on one thing - trying to close the gap in reproduced audio from unamplified live sound. And I post on my understanding of those realities; I certainly don't want or need a salesman's hat...:smile_phones:
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
post-14977208
Post #3,894 of 5,014
kerisabe
Studio
Studio
Website
Well said @Rob Watts thank you for creating qutest I am having a blast!
Reactions: blueninjasix
post-14977261
Post #3,895 of 5,014
Baten
Audiosciencereview: no jitter whatsoever
Stereophile measurement: no jitter whatsoever
-180dB seems a little exaggerated though. So you do have a salesman cap :) :)
post-14977314
Post #3,896 of 5,014
Triode User
Member of the Trade: WAVE High Fidelity
Leics, UK
Leics, UK
Have you considered that Rob might have better measuring equipment than the reviewers?
Reactions: Qute Beats
post-14977321
Post #3,897 of 5,014
Baten
I'm not sure what is better measuring than a $28000 APx555 man :p you tell me.
A better argument would be that measurements and highly dependant on the users' settings/config.
post-14977337
Post #3,898 of 5,014
Qute Beats
UK
UK
Website
www.last.fm
Thanks Rob, I'm satisfied that jitter is of no concern.
I guess the other issue that could arise would be a poor cable producing data transmission errors, which the DAC can't fix as in the signal already, but this would be clearly audible as clicks or pops AFAIK. As my cable does not have these issues I conclude that an upgrade is likely not needed (though I will look forward to @kerisabe doing a comparison :))
Reactions: Baten
post-14977538
Post #3,900 of 5,014
HumanMedia
Or maybe, like USB, the tranceivers that interpret the incoming signal generate noise internal to the receiving device, and the harder it is to interpret a jittery signal the more noise they generate. The digital data you hear is reclocked so no jitter there, but is there electrical noise from the tranceivers that can be heard?
Users Who Are Viewing This Thread (Users: 3, Guests: 9)
