Chord Electronics Qutest DAC - Official Thread
post-14971934
Post #3,841 of 5,062
Triode User
Member of the Trade: WAVE High Fidelity
Leics, UK
Leics, UK
Based on your headphones volume lisition of about 9.5 for the highest usual listening volume it could well be you would be better off with the Qutest 1v output setting.
Try it?
Reactions: Nik74
post-14972077
Post #3,842 of 5,062
kerisabe
Studio
Studio
Website
www.chrisbunjamin.com
Thanks for the replies guys. The amp im using is the Gryphon Diablo 300. I do have alot of room to move up on volume when the qutest is set to 1V. It doesnt say specifically if the input sensitivity is for balanced or unbalanced. Also it says the gain is +38dB and it also says the Input Impedans, single ended (20-20000Hz) is 20KOhm.
post-14972226
Post #3,843 of 5,062
dac64
US
US
All the stardand output of CD player or dac are 2V.
Chord just provides an option for users to fine tuning, to some, this feature may cause some confusions.
post-14972255
Post #3,844 of 5,062
kerisabe
Studio
Studio
Website
Thanks dac64. This issue is abit clearer for me. So i will try setting the qutest output to 1v and 2v and what are the things that i need to lookout for specifically? Thanks
post-14972677
Post #3,845 of 5,062
OctavianH
Brasov, RO
Brasov, RO
Somebody once told us here that the JCAT is a very good USB filter / card and makes the others useless. How right he was.
I started using this in my PC powered by an Sbooster LPS (+Sbooster Ultra) 2 days ago and now I just put on sale all my other USB filters (ISO Regen, iFi stuff and so on). This is a must for any desktop user, and they claim it needs at least 1 week to shine. I will need sun glasses if this is the sound quality I receive after 2 days. A very underrated product, imo.
post-14972684
Post #3,846 of 5,062
kerisabe
Studio
Studio
Website
Happy to hear youre achieving something with USB. I gave up USB last week and fed my qutest through its optical input from my macbook pro and voila, just limited to 24/96 since its an old 2010 mbp.
post-14972687
Post #3,847 of 5,062
OctavianH
Brasov, RO
Brasov, RO
I fully understand you and for this particular reason I always had a "plan B" with a CD Transport in Optical input (CXC) and direct CD playback. But now, after JCAT, plan B might not be needed anymore. Anway, since CXC was a steal for 400 EUR I will keep it to enjoy good old "CD playback" and to be able to see the cover and artwork of the music. :beyersmile:
What to say, if you have a free PCI express slot I would say you definitely need to check this JCAT Femto.
post-14972720
Post #3,849 of 5,062
Zzt231gr
Greece
Greece
post-14972744
Post #3,850 of 5,062
Zzt231gr
Greece
Greece
Hi ZZT,
Just to let you know I did do that on the Qutest review and did mention in the article on best dacs that using a linear psu on the Qutest is an improver for my system and ears. I do think it’s system dependent though as the box supplied psu is perfectly capable. Regards Simon
I 'd take that for a correct comment!
post-14973123
Post #3,851 of 5,062
jwbrent
California
California
Many toslink cables, including the excellent Lifatec glass toslink, won’t pass anything above 24/96. The solution is the Sys Concepts toslink which passes 24/192.
post-14973129
Post #3,852 of 5,062
kumar402
NY
NY
I have basic one from Amazon and it works fine with 24/192.
AmazonBasics Optical Toslink to Mini Toslink Jack Digital Audio Cable - 3 feet
post-14973138
Post #3,853 of 5,062
jwbrent
California
California
The Sys Concept, made in Canada, uses 1300 highly polished plastic fibers in its cables and can be custom made with different connectors and different lengths. I’ve owned a couple over the years, and it’s performance is top notch.
post-14973168
Post #3,854 of 5,062
Jon L
For him, f/1.2 is a prime number
post-14973205
Post #3,855 of 5,062
MagnusH
SWEDEN
SWEDEN
I use Lifatec and its 100% stable on 24/192 and DSD over DoP (which is 24/176), I use it on RME ADI-2 DAC though playing directly from computer.
Users Who Are Viewing This Thread (Users: 0, Guests: 13)
