Chord Electronics Qutest DAC - Official Thread
post-14969450
Post #3,826 of 5,068
The qutest is so good the only possible upgrade is apparently magic rocks and bricks. As heavy as the qutest is it doesn't need anything sitting on top of it. Or special feet. Or any other lunacy.
This is all the kind of thing that give the lot of us bad names everywhere else in audio. It disappoints me every time I read it.
post-14969474
Post #3,827 of 5,068
Joe-Siow
Jesus Christ, get over it already
post-14969495
Post #3,828 of 5,068
Baten
Here's a crazy idea. XLR interconnects and common mode rejection :)
post-14969541
Post #3,829 of 5,068
Yeah tell ME to be quiet while people push a product literally called "the magic brick" for three HUNDRED dollars. That offends me to my core and I'm going to say so. Don't really care what you think.
post-14969725
Post #3,830 of 5,068
Zzt231gr
Greece
Greece
It is the MAGIC that does the trick...
post-14969772
Post #3,831 of 5,068
jwbrent
California
California
To each his own ...
post-14969901
Post #3,832 of 5,068
schnesim
Munich
Munich
AFAIK Ted Smith throws away the clock info of the incoming data and reconstructs the packets through pattern matching to eliminate source jitter.
Does the Qutest do something similar? I'm asking since I'm wondering whether a separate reclocker will make sense with the Qutest.
post-14969946
Post #3,833 of 5,068
miketlse
post-14969955
Post #3,834 of 5,068
Baten
Reactions: Zzt231gr
post-14971064
Post #3,835 of 5,068
schnesim
Munich
Munich
Indeed. Most important part:
The measurements shown earlier in this thread and the Hugo 2 thread show zero measurable noise floor modulation and zero source and master clock jitter aberrations
Thanks! Just out of curiosity, do you have a link to the measurements? I tried using the search function, but without luck.
post-14971296
Post #3,836 of 5,068
x RELIC x
The West Coast, Canada
post-14971597
Post #3,837 of 5,068
kerisabe
Studio
Studio
Website
www.chrisbunjamin.com
Question about qutest output volt, if my amp’s input sensitivity is lower than qutest’s lowest output volt (at 0,617v) what are the solutions? Or i just have to suck it up and go with qutest’s lowest setting at 1V? Or is there any workaround it? @Rob Watts Thanks in advance Rob.
post-14971672
Post #3,838 of 5,068
kumar402
NY
NY
What amp are you using. If even 1v is hot for it then you need to invest in good preamp.
post-14971797
Post #3,839 of 5,068
Triode User
Member of the Trade: WAVE High Fidelity
Leics, UK
Leics, UK
It also depends on how your amp sensitivity is specified and what it means by "0.617v". Does it state 0.617v as being the input for a certain output?
Problems arise when an input voltage is too high for the amp sensitivity and then the volume control only has a small operating zone before the volume of the music becomes too loud. Also a too high an input voltage can cause the preamp stages to 'clip' and cause distortion (this is usually easy to hear and is often quite nasty).
However, in the great scheme of things, 0.6v is not all that different to 1v and I would say there is a good chance you will be OK with that.
Others may have a more detailed response if you can say what amp you are using.
post-14971889
Post #3,840 of 5,068
Nik74
London UK
London UK
A question while we re on the subject of amplifier input sensitivity: my amplifiers input sensitivity is 150mV but what I notice is that from the headphone out the highest volume setting I can listen at is about 9.5 position. Through my speakers I can go up to 12 . Could this mean that I need to use a different output setting for my Qutest when I listen through headphones? Output impedance is 1V/210 Ohm. I do feel that my volume control has a very small operting zone. I use the 2V setting
Reactions: HumanMedia
Users Who Are Viewing This Thread (Users: 1, Guests: 12)
