CHORD ELECTRONICS DAVE
Dec 4, 2018 at 4:27 PM Post #12,706 of 25,832
the new units are way better at handling thd you should look into the trade program they have
Thanks but I sold my P10 and do not miss it at all.
Dec 4, 2018 at 4:34 PM Post #12,707 of 25,832
I see so you believe that the Utopia's are just as easy to drive as a planar. The issue here is not unused power. The discussion is about power and paring.
Depends on the planar. Use the math to calculate the Current and Voltage required to drive, let's say, MrSpeakers ETHER Flow (96dB SPL/mw @1kHz, 23 Ohms). You'll see that it won't need anywhere what the DAVE is capable of to reach 120dB peaks. The ETHER Flow requires just 2.4V and 104.35mA, 250.43mW of power to reach 120dB peaks (again, VERY painfully loud). The dynamic driver Utopia is slightly different in the impedance curve because at 50kHz the impedance rises to over 300 Ohms so it will require more Voltage than the 80 Ohm @1 kHz impedance spec implies. However, this is also not an issue for the DAVE's output though (the DAVE's 500mA is quite a bit of Current for most planar headphones).
The speaker world knows these calculations VERY well and a user can calculate the power needed for the transducer taking in to account distance as well (headphones really don't require the distance SPL falloff calculation). On Head-Fi it's just myths and unicorns regarding power and generalizations, and it seems some users can't distinguish total design / tuning / synergy from output power.
I listen to the ETHER Flow (a planar headphone) at around -30 to -40 on the DAVE volume depending on the genre and track. So you are trying to tell me I need even more headroom because the output isn't enough. I don't think so.
Dec 4, 2018 at 4:57 PM Post #12,708 of 25,832
Really what about the Phi or Susvara -30 -40 ... most of my DAVE listening is at -15 sometimes to -9 if I'm in a mood....
Dec 4, 2018 at 5:00 PM Post #12,709 of 25,832
You will note that the whole time I have been addressing generalizations regarding planar headphones with the DAVE and the Phi and Susvara are a couple of rare instances that an external amp may benefit them for power required. There are plenty of other planar headphones besides the Phi and Susvara.
Dec 4, 2018 at 5:04 PM Post #12,710 of 25,832
Hehaw...
...you're quite unique here with your categorical statements – as if others haven't done their homework and made their own experiences with audio electronics. It's clear to me that your argumentation is based on personal preference, generalized with pseudo-scientific reasonings with no real scientific background apart from «well-known facts». Unused power is something that your amp will never use, so it can just as well be renounced. A good power supply is something else, but not dependent on output power.
What makes me definitely doubt your competence – in my view and according to my personal sonic ideal – is the fact that you don't even take notice of the loss of transparency by inserting another amplifier into the signal path, taking its signal from the DAVE's «headphone output», so to speak. Even with the added power reserves providing more «authority» or the like in your perception (euphonic colorations in my book) your immense experience should enable you to notice this factor – which is a crucial one for me.
My own experience has led me to a very reserved relationship with amplifiers. At the latest since experiments with headphones driven directly by an appropriate digital source (or its line out, respectively) in comparison with a headphone amp in the signal path. And recently I compared the Susvara – one of the headphones the DAVE can't drive (a well-known fact) – once driven by the DAVE and once via HiFiMan EF1000, a power machine par excellence, fine-tuned to the manufactuer's own TOTL planar headphone. And guess what: I preferred the direct connection by a fair margin. Much better transient response, higher transparency, tighter, better controlled bass, clearly better imaging...
BTW, at home I enjoy the HE1000 driven by the DAVE, and there's not the least itch to try one of my headphone amps with it – actually I could sell them. But who knows, maybe one day there's a new best headphone on the market that I want and the DAVE really can't drive.
Dec 4, 2018 at 5:25 PM Post #12,711 of 25,832
Hehaw...
I really don't care what you think about my competency... I don't see you putting formulas out there. Amps drive planars better period... show me the math on the Susvara and Phi ...
Dec 4, 2018 at 5:26 PM Post #12,712 of 25,832
Those are some of the best... let's see the calcs.. mr. I've been around...
Dec 4, 2018 at 5:45 PM Post #12,714 of 25,832
Yes, of course, we agree on this. The difference is that generalizations were being made that aren't accurate. For someone's preference it's a different story. I'm NOT debating that someone likes an amp better. I'm saying that the generalization that planar headphones need unused power is false. The DAVE has far and above enough power (Current and Voltage) for loads of headroom for 120dB SPL dynamic peaks (hopefully no one listens that loud) without distortion using MOST planar headphones.
This isn't about spare power not needed, more about efficiency of the HP used. The Utopia is way more efficient than the LCD4 200ohm. I heard the LCD4 out of the DAVE at Can-Jam, and the volume was at +6 for normal listening. On the Utopia is looked it was on -9.
The LCD4 out if the GSX on the next stand sounded much bigger, better dynamics and generally more alive. Yes, out of the DAVE it is transparent, but everything else less impressive. So this leads me to believe the LCD4 is quite hungry. The Abyss even more so, and the HE-6 a disaster needing a speaker amp....
Dec 4, 2018 at 5:50 PM Post #12,715 of 25,832
The sound was smoother and blacker, better dynamics and less edgy I think is the best description. I am assuming that was effect of the noise, but it could also be the wave form and less line distortion. There is a Multiwave on the P10 which also improves the sound to my ears, better bass definition. It brings the 2am sound to all day listening is the best way to describe this.
If anyone here finds they love that 2am sound, this is why - line distortion and noise in the mains (IMO).
It is also because everyone is sleeping, the background noise is minimal. There is calmness to the surroundings.
Dec 4, 2018 at 5:51 PM Post #12,716 of 25,832
Nice attitude.
You really think others aren't aware of what's considered the best or not? I'm well aware of the Abyss Phi and Susvara. I've heard the Susvara, and a few others like the LCD-4 but not the Phi. This will be my last reply to you.
Susvara required power (of course, add some headroom above these numbers - 20% is a good place to start):
Abyss Phi required power (of course, add some headroom above these numbers - 20% is a good place to start):
Edit: I purchased the Cavalli Liquid Gold amp because it has been reported to be the perfect pairing for the Abyss AB-1266, as that was in my plans a couple years ago. Don't assume I don't know about these other headphones.
Dec 4, 2018 at 5:54 PM Post #12,717 of 25,832
Please re-read my posts regarding generalizations and not cherry picking difficult to drive planars.
If listening to the Utopia at -9 on the DAVE the listener either has hearing damage, or is on their way to it if they don't consider that too loud, or the source music is exceptionally low. I listen to the Utopia in the -25 to -35 range from the DAVE for an average of 85-90dB SPL. Also, I didn't bring Utopia in to the conversation so let's not dwell on it.
Regarding efficiency, one MUST look at the sensitivity spec, not the impedance. The impedance will determine the ratio between Voltage and Current required. Higher impedance requires more Voltage and lower impedance requires more Current.
Dec 4, 2018 at 7:19 PM Post #12,720 of 25,832
Nice attitude.
Don't assume that I don't think you don't assume that you assume you don't assume that I don't think you do Mr. I've been around eg.. these need amps... thanks for the charts
