Jawed
- Dec 7, 2014
DAVE is sensitive to RF noise, wherever it comes from.
Blu 2 generates some RF noise itself and streaming sources that you connect to Blu 2 will also generate some RF noise, which Blu 2 passes on to DAVE. The RF "adds up" when it gets to DAVE, so both the noise from the streaming source and Blu 2's own noise affect DAVE.
You can use strong filtering on the cables that connect Blu 2 to DAVE to prevent any audible problem in DAVE caused by the RF noise. If the filtering is strong enough, then you won't hear a difference between CD replay (RF noise solely from Blu 2) and streaming source (both RF noise sources "adding up").
Opinions vary on the best way to filter the connection between Blu 2 and DAVE. Inevitably it requires lots (tens) of ferrites on each cable. There's no point in using just one or two ferrites.
A useful technique to minimise the noise that Blu 2, alone, can inject into DAVE (i.e. without a streaming source connected to Blu 2) is to use a single electrical plug for the mains cables that go into Blu 2 and DAVE. This minimises the voltage differential that can exist between Blu 2 and DAVE. A voltage differential is what helps the RF noise travel into DAVE.
In general when building a hi-fi, all the components should have their power cables going into a single plug. And all the cables should be the same length and manufacture, so that their electrical measurements are effectively identical. But it's quite difficult to fit more than 2 cables into a single plug!
Additionally, since DAVE will detect RF noise on all of its inputs simultaneously, there should only be a single device connected to DAVE. If you have a USB or an AES connected device plugged into DAVE as well as Blu 2, then you will suffer RF noise from that other device while you are listening to Blu 2. Disconnect it from DAVE to find out if you can hear a problem. A device connected with optical cable can't cause an RF problem so it's safe to leave it connected.
Now playing: Wolf Alice - Giant Peach
