CHORD ELECTRONICS DAVE
post-12665419
Post #3,391 of 14,637
paulchiu
Sennheiser 666
Manhattan
Manhattan
Has anyone tried an Intona USB isolator with a DAVE (or TT)? Does it work? Does it offer any benefit? Any thoughts or experiences would be welcome. Seems to me that cleaning up the USB signal can't be a bad idea.
Things like the Regen has a noticeable effect with Hugo and ZX2 players but with Chord Dave and Nagra HD DAC, the effects are minimal to none.
Paul
post-12665457
Post #3,392 of 14,637
rkt31
usb data can have jitter which is corrected by Dave. but usb data can also have some noise which may creep into the electronics. so a less noisy source can have some improvements with dave as reported by some members. so theoretically a usb reclocker is not required for dave. imho adding more active electronics around dave can have some minor negative effects so instead passively removing/blocking noise through usb cable may be a better idea with dave. imho try a single ferrite core near dave end on the usb cable and also use a audioquest jitterbug between usb port of pc and cable. contrary to what the name suggests jitterbug only removes noise from usb power passively (jitterbug does not require external power) and does not relcock data.
post-12665831
Post #3,393 of 14,637
esimms86
Rob states emphatically that DAVE via USB has full galvanic isolation(see post #3384) so I don't see what the Intona would have to offer you in this case. That's 300 USD that you can spend on music instead.
post-12666986
Post #3,394 of 14,637
Arpiben
I fully agree your point, but I still have a small doubt regarding the fact that, in my mind, in order to be fully efficient galvanic isolation has to be applied at both ends; i.e. Player/DAP output and DAC input.
Otherwise the isolation at DAC input will not remove the jitter/noises/RFI eventual modulations generated at DAP Output.
For sure DAVE has got other 'tricks/solutions' to remove those further ahead in data audio chain for removing them..
If Rob or somebody else can elaborate/detail more this point I will aprreciate.
Rgds
post-12667004
Post #3,395 of 14,637
x RELIC x
The West Coast, Canada
Rgds
This post, and subsequent posts on the same page, by Rob might help:
http://www.head-fi.org/t/766517/chord-electronics-dave/2925#post_12577889
Agreed that jitter is not an issue with Dave; nor with any of my other DAC's. We can see this on the measured performance with Dave, as there simply are not any artefacts:
The reason why I am so confident that jitter is a non issue is because of a number of things:
1. USB operation gets its timing from the local Dave oscillator, and incoming data gets re-locked to the local clock.
2. When I add 2 uS (that's 2,000,000 pS of jitter) to the data input from the AP using optical or coax I measure absolutely no change whatsoever. Now that on its own is not enough, as I have had situations before where unmeasurable effects are audible - but not concerning jitter. I have always been able to hear an effect then measure it.
3. One way that an incoming data can effect the SQ is down to ground plane noise, and in the past this used to be a big issue, both in measurement and SQ. And it's technically possible that ground plane and power supply noise can affect the SQ (I have seen this many times before). But in the case of my modern DAC's I have been able to eliminate this issue by a combination of local RF filtering on power supplies, double layer ground planing,use of efficient local SMPS, and power efficient FPGA's, plus careful layout. Now this issue used to be a nightmare, particularly with the FPGA, when my DSP cores used power hungry FPGA fabric. I would have to construct a DSP core by creating my own multipliers (today I use dedicated FPFA resources that are extremely power efficient), and every time a new place and route occurred, I would get different sound and different measurements. Today this situation never happens for lots of reasons - better design of the ground planes, better local RF filtering, better quality of RF filters, and dramatically lower signal induced noise (actually this is thousands of times lower than ten years ago) from the FPGA. Today, different place and routes show no SQ changes, or measured changes. What I am alluding to here is that the noise from a jittery source can't upset the sound quality through induced noise, as it is now (as far as I can tell) completely isolated - its also one of the benefits of the USB galvanic isolation in that the USB processor gnd and PSU noise is isolated from Dave.
4. Pulse Array DAC is innately jitter insensitive. What is not readily appreciated is that different DAC architectures have very different sensitivity to clock jitter. DSD is horribly sensitive to jitter, R2R DAC's are very sensitive, but pulse array is innately insensitive. The reason for this is that signal switching activity is completely signal independent - it switches in exactly same way whether its reproducing 0 of fully positive or negative. Because of this, when I get some clock jitter, it only creates a fixed noise. Now one of the really cool things that happens today is that PC resources and simulation tools are so good today, in that I can write a simulation, and add some jitter to the simulation, then measure the results using an FFT. From this, I can see exactly what jitter and only jitter does - and this technique has revealed a few surprises. But what it has done is proven that adding random jitter creates zero signal correlated effects to pulse array - no distortion, noise floor modulation at all - just an insignificant level of unvarying random noise. This does not happen with other DAC architectures, as you will then get significant noise floor modulation, distortion and noise shaper related noise. This is because with the other types of DACs, the switching activity is signal related. So DSD has maximum switching reproducing zero, and no switching at 100% modulation. R2R has no activity for zero, but considerable switching activity when the signal changes.
As to RF noise yes it is like a fungal infection. In the mid 80's, when I began to appreciate the importance of RF noise, I created a RF noise mains filter, in order to eliminate the SQ changes that mains cable was making. This ended up being a scary design - a cascade of inductors and capacitors, with filtering from 100 kHz to over 1GHz. I even had to make my own PTFE air cored inductors to get the performance I needed. But it worked - you could absolutely not hear the effects of different mains cable before the filter, but I had to use insane levels of filtering.
So I know how crazily sensitive things are to RF noise, which is why I can't say for absolute certainty that RF noise from Dave or from the sources may or may not affect your system - simply as most power amplifiers are very RF sensitive. So it really is a case of YMWV. But I would like to make a few suggestions:
1. PSU design - as far as impedance is concerned, forget it in relation to RF noise. Now impedance is an important issue, but it has no bearing on RF noise. It can be important in that signal currents will cause distortion due to the OP impedance. That's why the reference power supply for the pulse array is less than 0.0005 ohms for each and every flip flop as that is an important source of distortion. But it has no bearing on RF noise, that is another issue. But today, filtering within the DAC can be done to a very high level of performance with modern SMD capacitors, inductors and ferrite beads.
2. Source - my advice with Dave is to use a source that is convenient for you. So far, in my system - and again YMMV, I have failed to hear any significant difference between different sources.
3. RF noise in terms of SQ. When you reduce RF noise, things sound softer and warmer and smoother. Bass is rounder with less slam and impact. Now if it is a bit perfect input source you are making changes, the only thing that can make a difference to the SQ is RF noise, so go for the warmer and softer sound - as that is the most transparent - even if it sounds too smooth! If it is too soft, don't worry - it is not a problem - you just need to then improve transparency elsewhere in your system - such as better cables, changing where the loudspeakers are sited, different HP, EQ etc. One of the profound problems we have with audio is that making fundamental improvements may affect the balance of the system, so it is less optimum. The trick is to understand when you have indeed made a fundamental improvement but that gives you an unbalanced sound then make other changes in your system to restore the overall balance.
Happy listening, Rob
Also, there's this very helpful summary of Rob's posts by romaz:
http://www.head-fi.org/t/766517/chord-electronics-dave/1395#post_12262339
If you guys are interested in a really good read, just check out all of Rob's posts -- you'll come out feeling a lot smarter. I've compiled some of Rob's comments that are among my favorites (if you are not able to locate certain comments I have attributed to Rob as comments he has publicly made on Head-Fi, it is because some of the comments were made privately to me). Some comments were made with respect to the Mojo but should apply equally to the DAVE. Consider some of his answers as best practices with the DAVE.
What is most important with the DAVE?
[COLOR=0000CD]In simple terms its about resolution first, then less jitter sensitivity, lower distortion and noise.
Subjectively the resolution gives better depth perception, and lower THD and noise gives smoother sound.
[/COLOR]
Why do you believe SE is better than balanced for a DAC?
[COLOR=0000CD]Well this is a complex subject, and sometimes a balanced connection does sound better than single ended (SE) - in a pre-power context - but it depends upon the environment, and the pre and power and the interconnect. But the downside of balanced is that you are doubling the number of analogue components in the direct signal path, and this degrades transparency. In my experience every passive component is audible, every metal to metal interface (including solder joints - I once had a lot of fun listening to solder) has an impact - in case of metal/metal interfaces it degrades detail resolution and the perception of depth. So going balanced will have a cost in transparency.
In DAC design, going balanced is essential with silicon design; there is simply too much substrate noise and other effects not too. But with discrete DAC's you do not need to worry about this, so going SE on a discrete DAC is possible, and is how all my DAC's are done. But differential operation hides certain problems (notably reference circuit) that has serious SQ effects; so going SE means those problems are exposed, which forces one to solve the issue fundamentally. In short, to make SE work you have to solve many more problems, but the result of solving those problems solves SQ issues than differential operation hides when you do measurements.
In the case of Dave, I have gotten state of the art measured performance - distortion harmonics below -150 dB, zero measurable noise floor modulation - and there is no way you could do this with a differential architecture. So it is possible to have better measured performance with SE than differential, but it is a lot harder to do it - indeed, the only way of getting virtually zero distortion and noise floor modulation is SE.
[/COLOR]
What are distortion figures for the DAVE?
[COLOR=0000CD]Distortion components are all below -150dB, so better than 24 bits. Noise is 21 bits. But these numbers, although very important, won't tell you how good it sounds. Noise floor modulation, which is important, is un-measurable, and with my APX555 the noise floor is at -180dB.[/COLOR]
Why do vocals sound so good on the DAVE?
[COLOR=0000CD]
The simple answer to why vocals sound so good on Mojo is complete lack of noise floor modulation.
[/COLOR]
What is noise floor modulation?
[COLOR=0000CD]What is noise floor modulation? When a sine wave signal is used in a DAC, you get different types of distortion - harmonic distortion (distortion of integer multiples from the sine wave fundamental) enharmonic distortion (distortion products that are non integer) and changes to the noise level. So for example you may have a DAC that produces noise at -120dB with -60dB sine wave (traditional dynamic range test) but the noise with a 0dB sine wave maybe -115dB - thus the noise has increased by reproducing a higher level sine wave - in this case the noise floor (seen by doing an FFT measurement) would increase by 5dB.
Now noise floor modulation is highly audible - it interferes with the brain's processing of data from the ear - and immeasurably small levels of noise floor modulation is audible. I know this as I have listened to noise floor modulation at around -200dB - these numbers are derived from simulation - and heard the effect when the noise floor modulation mechanism was switched on and off.
[/COLOR]
What does noise floor modulation sound like?
[COLOR=0000CD]Noise floor modulation is extremely important subjectively - you perceive the slightest amount as a brightness or hardness to the sound. When it gets bad, you hear glare or grain in the treble.
Less noise floor modulation, smoother sound quality. The curious thing about this is that the brain is very sensitive to it, so you can easily hear it. Problem is that many listeners hear the brightness as more detail resolution, and so think it sounds better - but that's another story.[/COLOR]
What is clock jitter, total jitter, source jitter?
[COLOR=0000CD]Clock jitter is timing uncertainty (or inaccuracy) on the main clock that is feeding the digital outputs. Its often expressed as cycle to cycle jitter as an RMS figure, but can be total jitter which includes low frequency jitter too. Total jitter is the most important specification. If you want here is a good definition:[/COLOR]
https://en.wikipedia.org/wiki/Jitter
[COLOR=0000CD]As you can see, the jitter subject can get complicated and its often abused by marketing...
But with all of my DAC's you do not need to worry at all about source jitter, so all of the above AK numbers are fine. So long as its below 2uS (that is 2,000,000 pS) you are OK, and nobody has jitter that bad!
1. SPDIF decoding is all digital within the FPGA. The FPGA uses a digital phase lock loop (DPLL) and a tiny buffer. This re-clocks the data and eliminates the incoming jitter from the source. This system took 6 years to perfect, and means that the sound quality defects from source jitter is eliminated. How do I know that? Measurements - 2 uS of jitter has no affect whatsoever on measurements (and I can resolve noise floor at -180dB with my APX555) and sound quality tests against RAM buffer systems revealed no significant difference. You can (almost) use a piece of damp string and the source jitter will be eliminated.
2. USB is isochronous asynchronous. This means that the FPGA supplies the timing to the source, and incoming USB data is re clocked from the low jitter master clock. So again source jitter is eliminated.
[/COLOR]
Does the DAVE have a fancy FEMTO clock like other DACs to help reduce jitter?
[COLOR=0000CD]The issue of clocks is actually very complex, way more of a problem then in simply installing femto clocks. People always want a simple answer to problems even if the problem is multi-dimensional and complex. I will give you a some examples of the complexities of this issue.
Some years back a femto clock became available, and I was very excited about using it as it had a third of the cycle to cycle jitter of the crystal oscillators we were using. So I plugged it in, and listened to it. Unexpectedly, it sounded brighter and harder - completely the opposite of all the times I have listened to lower jitter. When you lower jitter levels in the master clock, it sounds smoother and warmer and more natural.
So I did some careful measurements, and I could see some problems.
The noise floor was OK, the same as before, and all the usual measurements were the same. But you could see more fringing on the fundamental, and this was quite apparent. Now when you do a FFT of say a 1 kHz sine wave, in an ideal world you would see the tone at 1 kHz and each frequency bucket away the output would be the systems noise floor. That is, you get a sharp single line representing the tone. But with a real FFT, you get smearing of the tone, and this is due to the windowing function employed by the FFT and jitter problems within the ADC, so instead of a single line you get a number of lines with the edges tailing of into the noise. This is known as side lobes or fringing. Now one normally calibrates the FFT and the instrument so you know what the ideal should be. Now with a DAC that has low frequency jitter, you get more fringing. Now I have spent many years on jitter and eliminating the effects of it on sound quality, and I know that fringing is highly audible, as I have done many listening tests on it. What is curious, is that it sounds exactly like noise floor modulation - so reduce fringing is the same as reducing noise floor modulation - they both subjectively sound smoother and darker with less edge and hardness.
So a clock that had lower cycle to cycle jitter actually had much worse low frequency jitter, and it was the low frequency jitter that was causing the problem and this had serious sound quality consequences. So a simple headline statement of low jitter is meaningless. But actually the problem is very much more complex than this.
What is poorly understood is that DAC architectures can tolerate vastly different levels of master clock jitter, and this is way more important than the headline oscillator jitter number. I will give you a few examples:
1. DAC structure makes a big difference. I had a silicon chip design I was working on some years back. When you determine the jitter sensitivity you can specify this - so I get a number of incoming jitter, and a number for the OP THD and noise that is needed. So initially we were working with 4pS jitter, and 120dB THD and noise. No problem, the architecture met this requirement as you can create models to run simulations to show what the jitter will do - and you can run the model so only jitter is changed, nothing else. But then the requirements got changed to 15 pS jitter. Again, no problem, I simply redesigned the DAC and then achieved these numbers. So its easy to change the sensitivity by a factor of 4 just by design of the DAC itself - something that audio designers using chips can't do.
2. DAC type has a profound effect on performance. The most sensitive is regular DSD or PDM, where jitter is modulation dependent, and you get pattern noise from the noise shaper degrading the output noise, plus distortion from jitter. R2R DAC's are very sensitive as they create noise floor modulation from jitter proportionate to the rate of change of signal (plus other problems due to the slow speed of switching elements). I was very concerned about these issues, and its one reason I invented pulse array, as the benefit of pulse array is that the error from jitter is only a fixed noise (using random jitter source with no low frequency problems). Now a fixed noise is subjectively unimportant - it does not interfere with the brains ability to decode music. Its when errors are signal dependent that the problems of perception start, and with pulse array I only get a fixed noise - and I know this for a fact due to simulation and measurements.
3. The DAC degrades clock jitter. What is not appreciated is that master clock jitter is only the start of the problem. When a clock goes through logic elements, (buffers level shifters, clock trees gates and flip-flops plus problem of induced noise) every stage adds more jitter. As a rough rule of thumb a logic element adds 1 pS of more jitter. So a clock input of 1pS will degrade through the device to be effectively 4 pS once it has gone through these elements (this was the number from a device I worked on some years ago). So its the actual jitter on the DAC active elements that is important not the clock starting jitter.
The benefit I have with Pulse Array is that the jitter has no sound quality degrading consequences - unlike all other architectures - as it creates no distortion or noise floor modulation. Because the clock is very close to the active elements (only one logic level away), the jitter degradation is minimal and there are no skirting issues at all. This has been confirmed with simulation and measurement - its a fixed noise, and by eliminating the clock jitter (I have a special way of doing this) noise only improves by a negligible 0.5 dB (127 dB to 127.5 dB).
This is true of all pulse array DAC's even the simpler 4e ones. In short the jitter problem was solved many years ago, but I don't bleat on about it as its not an issue and because it's way too complex a subject to easily discuss.
Pulse Array is a constant switching scheme - that is it always switches at exactly the same rate irrespective of the data, unlike DSD, R2R, or current source DAC's. This means that errors due to switching activity and jitter are not signal dependent, and so is innately immune from jitter creating distortion and noise floor modulation and any other signal related errors. The only other DAC that is constant switching activity is switched capacitor topology, but this has gain proportionate to absolute clock frequency - so it still has clock problems.
I plan to publish more detailed analysis of this, but from memory all of my DAC's have a negligible 0.5dB degradation due to master clock jitter, so its a non issue.
And yes you are correct, the absolute frequency is quite unimportant, so forget oven clocks, atomic clocks etc. Also the clock must be physically close to the active elements,with dedicated stripline PCB routing with proper termination. Running the clock externally is a crazy thing to do, as you are simply adding more jitter and noise and an extra PLL in the system.
[/COLOR]
With the DAVE, does the quality of the source matter?
[COLOR=0000CD]Dave is insensitive to the digital source, assuming the data is bit perfect.[/COLOR]
How is the DAVE impervious to low quality source components like a basic laptop to the extent that they can sound equivalent go a very expensive, purpose-built music server?
[COLOR=0000CD]Going back to when Hugo first came out, I noticed different SQ with different lap-tops and PC's.
Now the problem is definitely not jitter from the source - my DAC's can tolerate 2uS of jitter and it will have zero difference to the measurements - also the USB is isochronous asynchronous so the timing comes from the DAC clock, so source jitter is not a problem.
So I looked into the issue of different SQ with sources and found two sources of error:
1. RF noise. RF noise is a major pain with audio. With analogue electronics, very tiny amounts of RF noise will cause intermodulation distortion with the audio signal, and the intermodulation products is noise floor modulation.
2. Correlated current noise. If a tiny current that is signal related but distorted enters the ground plane, then this current will be a source of error, as the current in the ground plane induces small voltages. Now this then adds or subtracts to small signals, thus degrading small signal resolution - and this upsets the brains ability to calculate depth. Now one of the most fascinating things I discovered with Dave is there is no limit to how small this error can be without a degradation in depth perception - so it does not matter how small the error is it will have an impact.
So the solution to the above problems is galvanic isolation. This means that RF noise from the source can't get into Dave, and small correlated currents can't get in too. And this approach gave two benefits - much smoother sound quality, and a deeper soundstage.
Now with Dave I can no longer hear which source is connected, but before without the galvanic isolation it was easy to hear.
[/COLOR]
USB is widely believed to be a noisy interface. Some music server companies (Baetis) suggest you should avoid USB at all costs and that SPDIF is superior. Does this apply to the Mojo or DAVE?
[COLOR=0000CD]Just to make it 100% clear - the USB input will measure absolutely identically to the coax or optical inputs if the USB data is bit perfect.
I have set up my APX555 so that it uses the USB via ASIO drivers, and I get exactly the same measurements on all inputs - 125 dB DR, THD and noise of 0.00017% 3v 1k 300 ohms. I have done careful jitter analysis, FFT analysis down to Mojo's -175dB noise floor, and can measure no difference whatsoever on all inputs (with the APX always grounded on the coax).
If somebody does measure a difference its down to mangled data on the USB interface (or perhaps poor measuring equipment...)
[/COLOR]
Which input sounds the best on the DAVE?
[COLOR=0000CD]With Dave the best input (by a tiny margin) is USB, then optical is very close. The BNC/AES depends upon the source and cabling.
[/COLOR]
Does the DAVE's USB require 5V power?
[COLOR=0000CD]It needs the 5V to power the USB decoder chip - this is how the galvanic isolation works, as the isolation is on the decoded I2S data post USB.[/COLOR]
What USB cables are best?
[COLOR=0000CD]So what are the best USB cables? Firstly, be careful. A lot of audiophile USB cables actually increase RF noise and make it sound brighter, and superficially impressive - but this is just distortion brightening things up. Go for USB cables that have ferrites in the cable is a good idea - it may also solve any RF issues from the mobile that you may have too.[/COLOR]
What about USB purifiers/reclockers (USB Regen)?
[COLOR=0000CD]As to USB purifiers, for Dave, Hugo TT, 2 Qute don't bother as they are galvanically isolated. But in this case it's absolutely nothing due to jitter - its about RF noise and signal correlated noise upsetting Hugo.'s analogue electronics,not due to jitter as source jitter is eliminated by the internal buffer and DPLL.[/COLOR]
What about SPDIF cables, will any SPDIF cable do?
[COLOR=0000CD]Sadly no. Mojo is a DAC, that means its an analogue component, and all analogue components are sensitive to RF noise and signal correlated in-band noise, so the RF character of the electrical cables can have an influence. What happens is random RF noise gets into the analogue electronics, creating intermodulation distortion with the wanted audio signal. The result of this is noise floor modulation. Now the brain is incredibly sensitive to noise floor modulation, and perceives this has a hardness to the sound - easily confused as better detail resolution as it sounds brighter. Reduce RF noise, and it will sound darker and smoother. The second source is distorted in band noise, and this mixes with the wanted signal (crosstalk source) and subtly alters the levels of small signals - this in turn degrades the perception of sound stage depth. This is another source of error for which the brain is astonishingly sensitive too. The distorted in band noise comes from the DAP, phone or PC internal electronics processing the digital data, with the maximum noise coming as the signal crosses through zero - all digital data going from all zeroes to all ones. Fortunately mobile electronics are power frugal and create less RF and signal correlated noise than PC's. Note that optical connection does not have any of these problems, and is my preferred connection.
Does this mean that high end cables are better? Sadly not necessarily. What one needs is good RF characteristics, and some expensive cables are RF poor. Also note that if it sounds brighter its worse, as noise floor modulation is spicing up the sound (its the MSG of sound). So be careful when listening and if its brighter its superficially more impressive but in the long term musically worse. At the end of the day, its musicality only that counts, not how impressive it sounds.
[/COLOR]
Do AC cables make a difference?
[COLOR=0000CD]In the 1980's, people started talking about mains cables making a difference to the sound quality - and I didn't believe it either - particularly as my pre-amp had 300 dB of PSU rejection in the power supply. But I did a listening test, and yes I could hear a difference. Frankly I still could not believe the evidence of my own ears, so did a blind listening test with my girl friend. She reported exactly the same observation - mains cables did make a difference to SQ.
To cut a long story short, I proved the problem was down to RF noise. RF noise inter-modulates with the wanted audio signal within the analogue electronics, and if the RF noise is random, then the distortion is random too and you get a increase in noise floor with signal. This increase in noise floor is noise floor modulation, and the brain is very sensitive to it...
[/COLOR]
Should you connect the DAVE to a line conditioner?
[COLOR=0000CD]Give RF filters a go. Dave has an incredible amount of RF filtering internally, but you may get a benefit for other gear with RF isolation. If it sounds smoother and darker its better is the rule here - this will also make dynamics seem quashed too, but that's just reducing noise floor modulation.[/COLOR]
Is there a problem leaving the DAVE on 24/7 or is it best to put it into standby mode or turn it off completely at the end of each day?
[COLOR=0000CD] I leave both my Daves on all the time - but I am just lazy...[/COLOR]
Does the DAVE benefit from mechanical isolation (Stillpoints, etc)?
[COLOR=0000CD]Yes all products do.
[/COLOR]
Should the HF filter be used for both hi-res files as well as 16/44?
[COLOR=0000CD]The HF filter is a sharp cutoff filter set to 60 kHz. The intention was to bandwidth limit high sample rate recordings - DXD and 384k have huge amounts of noise shaper noise from the ADC. This noise will degrade SQ by increasing noise floor modulation as the out of band noise creates intermodulation distortion with the wanted audio signal in the analogue electronics.
Now it works very well, in using it makes it sound smoother and darker - exactly what you get from lower noise floor modulation. But the curious thing is that it also sounds better with 44.1 k - curious because the WTA filter typically has a stop band attenuation of 140 dB (worst case 120 dB). So out of band noise is very low with 44.1 k and I was not expecting a SQ change with the filter with CD. The filter is not something added, its just a different set of coefficients for the 16 FS to 256 FS WTA filter.
[/COLOR]
On upsampling the source (i.e. HQPlayer) with Chord products:
[COLOR=0000CD]
Oh dear. Do NOT use your computer to up-sample or change the data when you use one of my DAC's.
All competent DAC's up-sample and filter internally; the issue is how well that filtering is done, in terms of how well the timing of transients is reconstructed from the original analogue. Computers are poor devices to use for manipulating data in real time as they are concurrent serial devices - everything has to go through one to 8 processors in sequence. With hardware and FPGA's you do not need to do that, you can do thousands of operations in parallel. Dave has 166 DSP cores with each core being able to do one FIR tap in one clock cycle. That is incredibly powerful processing power way more powerful than a PC.
But its not just about raw processing power but the algorithm for the filter. The WTA filter is the only algorithm that has been designed to reduce timing of transients errors, and the only one that has been optimised by thousands of listening tests.
So the long and the short is don't let the source mess with the signal (except perhaps with a good EQ program) and let Mojo (or DAVE) deal with the original data, as Mojo (or DAVE) is way more capable
[/COLOR]
On why you shouldn't upsample PCM to DSD and why PCM sounds better than DSD:
[COLOR=0000CD]DSD as a format has major problems with it; in particular it has two major and serious flaws:
1. Timing. The noise shapers used with DSD have severe timing errors. You can see this easily using Verilog simulations. If you use a step change transient (op is zero, then goes high) with a large signal, then do the same with a small signal, then you get major differences in the analogue output - the large signal has no delay, the small signal has a much larger delay. This is simply due to the noise shaper requiring time for the internal integrators to respond to the error. This amplitude related timing error is of the order of micro seconds and is very audible. Whenever there is a timing inaccuracy, the brain has problems making sense of the sound, and perceives the timing error has a softness to the transient; in short timing errors screw up the ability to hear the starting and stopping of notes.
2. Small signal accuracy. Noise shapers have problems with very small signals in that the 64 times 1 bit output (DSD 64) does not have enough innate resolution to accurately resolve small signals. What happens when small signals are not properly reproduced? You get a big degradation in the ability to perceive depth information, and this makes the sound flat with no layering of instruments in space. Now there is no limit to how accurate the noise shaper needs to be; with the noise shaper that is with Mojo I have 1000 times more small signal resolution than conventional DAC's - and against DSD 64 its 10,000 times more resolving power. This is why some many users have reported that Mojo has so much better space and sounds more 3D with better layering - and its mostly down to the resolving power of the pulse array noise shaper. This problem of depth perception is unlimited in the sense that to perfectly reproduce depth you need no limit to the resolving power of the noise shaper.
So if you take a PCM signal and convert it to DSD you hear two problems - a softness to the sound, as you can no longer perceive the starting and stopping of notes; and a very flat sound-stage with no layering as the small signals are not reproduced accurately enough, so the brain can't use the very small signals that are used to give depth perception.
So to conclude; yes I agree, DSD is fundamentally flawed, and unlike PCM where the DAC is the fundamental limit, its in the format itself. And it is mostly limited by the format.
[/COLOR]
And my favorite comment from Rob (this one is regarding the Mojo):
[COLOR=0000CD]I was kind of annoyed that some people were comparing it to $100 DACs when the true competitors were $100K.[/COLOR]
Reactions: Mython and Arpiben
post-12667045
Post #3,396 of 14,637
Rgds
This is a good question, and something I have been puzzling over myself - thrown into focus when I heard that my lap-top sounds a bit smoother on battery operation than with the PSU connected. By using batteries you are effectively double isolating, as it is no longer connected via the mains supply and the lap top ground is completely floating.
Now we have two effects going on when you galvanically isolate; reduction in RF noise via ground loops, and the elimination of audio currents (signal related but distorted principally due to the massive change as all bit flip from 1 to zero as you cross through analogue zero).
Now the galvanic isolation is not 100% as there is a residual 2pF coupling capacitance. At 1 kHz this represents 79 M ohms - so low frequency noise will be eliminated. But at 1 GHz its a much smaller 79 ohms - so is more significant and potentially a problem.
So is the lap top isolation because Dave is getting noise via the mains, or is it through the 2pF galvanic isolation?
Well it occurred to me that I can test this out using Audioquest Jitter bug - which acts as an RF filter so that you filter the ground power and signal lines. Now if I can hear no difference via the jitter bug, then that suggests that the RF noise path is via the mains. If the jitter bug means that using it reduces the effect of battery isolation then its via the galvanic isolation.
I am in Asia at the moment, and packed a Dave and a jitter bug, so as soon as Davina PCB is finished that is my next task.
I will report back on the results. I should emphasis that we are talking quite small differences here, it is something you can only just hear with careful AB tests - its certainly not a big issue.
Another point is another layer of galvanic isolation like the one in Dave at the source would not eliminate the problem - only half it. The 2pF becomes 1pF.... And the extra circuitry would create a bit more noise.
Rob
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
post-12667066
Post #3,397 of 14,637
Arpiben
Rob
Gratefully Thanks.
post-12668322
Post #3,398 of 14,637
AndrewOld
Rob
Rob, there's another possibly useful device called an Intona High Speed USB Isolator. See here: http://intona.eu/en/products
It apparently offers galvanic isolation, and rechecks the original data.
Intona publish lots of measurements and technical information here:
http://intona.eu/en/answer/1239
http://intona.eu/en/answer/1245
http://intona.eu/en/answer/1233
I don't understand most of this, but I dare say you will!
I would like to squeeze the last ounce of performance from my DAVE, which is utterly incredible I have to say, every day I listen to it I realise more how incredible it is, so I look forward to you getting to the bottom of your observations about running your laptop from batteries.
post-12672328
Post #3,399 of 14,637
analogmusic
I think it is important to trust Rob Watts and not get particularly obsessive about these Galvanic isolation issues
After reading many hundred of pages I am somewhat still perplexed about how many people still don't quite understand what Hugo and Dave are really about.
I'll only repeat what Rob has said many times below about listening fatigue being eliminated with his DACs
Originally Posted by Rob Watts
Its a brain issue, and is (mostly) down to two technical problems - one being noise floor modulation, one being timing uncertainty. With timing uncertainty, when the sampled digital data is converted back to a continuous signal, the DAC creates timing errors. These timing errors then interfere with the brains ability to actual perceive the starting and stopping of notes - and when the brain can't easily recognise something, it has to work harder to make sense of what is going on. Its a bit like one being in a party trying to understand somebody speaking with a lot of noise - your brain has to work harder to understand the voice, and its tiring. The noise floor modulation problem, means that the brain has greater difficulty separating sounds out into individual entities. What people forget, as we take hearing for granted, is that the brain is processing the data from the ears, and separating things out into individual entities, and also putting a placement tag onto that entity. Noise floor modulation makes it more difficult for the brain to separate things out into individual entities, so the brain has to work harder to make sense of the music. And when it has to work harder, you get listening fatigue.
Now the timing issue is a unique problem with digital audio, and noise floor modulation is about ten times a larger problem than with amplifiers, so you can see why listening fatigue is a particular problem with digital.
Rob
post-12674165
Post #3,400 of 14,637
Beolab
Member of the Trade (Reseller)
@Rob Watts
Just a curios question:
Is there any scheduled plans to design a dedicated streamer for the DAVE in the future, who can take benefit of your groundbreaking technology?
post-12674399
Post #3,401 of 14,637
esimms86
@Rob Watts
While I'm certain that Rob could work his usual musical magic in deserving a server to mate with DAVE, he's a man with a lot on his plate and I don't see where that's a priority of his right now.
In the meantime, the microRendu with the Uptone Audio JS-2 power supply works wonders when connected to DAVE and likely any other DAC for that matter. The midbass(particularly separating the sound of one percussion instrument from another) and midrange(particularly as it applies to reproducing the sound of a piano or the human voice) are especially outstanding with the microRendu when connected to DAVE and even lesser DACS(e.g., the Auralc Vega and Geek Pulse Infinty SE in my home). Instrument decay with the microRendu brings the aforementioned DACS even closer to DAVE territory. I'm personally over the moon with the microRendu and DAVE. If you can afford it, a higher end power supply relative to the iFi 9v PS is well worth the money.
Reactions: shuttlepod
post-12674491
Post #3,402 of 14,637
stvc
Any reason you choose JS-2 PS over of the snore signature PS?
post-12674515
Post #3,403 of 14,637
iDesign
Rob
Interesting. Looking forward to your thoughts on the merits of the JitterBug.
post-12674539
Post #3,404 of 14,637
maxh22
Out of curiosity, what differences have you heard when comparing the Vega and Dave? I'm very familar with the Vega sound so your input on how it compares would mean a lot.
post-12674567
Post #3,405 of 14,637
esimms86
I already had one powering other devices(the Auralic Aries, and the Geek Pulse Infinity SE). I also had an idle iFi 9v power supply sitting around.
My understanding, however, is that the Sonore Signature PS won't put you to sleep LOL!
Users Who Are Viewing This Thread (Users: 2, Guests: 7)
