jlbrach
- Jun 4, 2005
not if you use the dave as is ...
It’s an enthusiast summit-fi forum though. It’s not odd to mod equipment. Also, the initial talk of a DAVE and Susvaras has shifted to power supplies. I think that’s fair gamenot if you use the dave as is ...
So, I spent another afternoon and evening listening to my TCs straight out of my DC4’d mDAVE. Let’s put aside why it’s working for a moment and just discuss the sound. After further experimenting with the Dave driving my TCs, I’ve noticed some new things. 1) The DAVE/TCs combo is more unforgiving with poorly recorded material compared to my WA33. 2) After several hours, the sound became a little fatiguing. 3). The TC mids are worse out of the DC4’d DAVE. 4) The TCs have higher resolution out of the DAVE, which some would probably like. 5) The DAVE is somewhat clinical compared to my WA33, where strict accuracy seems to be the goal (it is a solid state though). 6) I like the “distortion” my WA33 and tubes bring, though I know some might prefer the more analytical and clinical DAVE.
So, there are some important differences between going out of the DAVE vs using a high-end tube amp. I’m really glad I have both. I’m moving back to the WA33 tomorrow and I should have more notes and comparisons.
Basically, if you have to choose between a DC4’d DAVE or getting an external tube amp for your stock DAVE, I think it will depend on if you value utmost accuracy or if you like tube “distortion.” Both drive the TCs and Susvaras well. So, it’s probably just personal preference![]()
U need to jump on the src dx train and do sorbothanes on it. Like I said, the USB in with my 40x lt3045 chain was still underwhelming. The harmonics that's in the track is muted. That's why tubes will sound good because it will emulate (poorly) the harmonics that's embedded in the track.So, I spent another afternoon and evening listening to my TCs straight out of my DC4’d mDAVE. Let’s put aside why it’s working for a moment and just discuss the sound. After further experimenting with the Dave driving my TCs, I’ve noticed some new things. 1) The DAVE/TCs combo is more unforgiving with poorly recorded material compared to my WA33. 2) After several hours, the sound became a little fatiguing. 3). The TC mids are worse out of the DC4’d DAVE. 4) The TCs have higher resolution out of the DAVE, which some would probably like. 5) The DAVE is somewhat clinical compared to my WA33, where strict accuracy seems to be the goal (it is a solid state though). 6) I like the “distortion” my WA33 and tubes bring, though I know some might prefer the more analytical and clinical DAVE.
I am intrigued. Plus @edwardsean said he liked them too, and he uses a DC4 as well I think. I need to look into the src dx more tomorrow.U need to jump on the src dx train and do sorbothanes on it. Like I said, the USB in with my 40x lt3045 chain was still underwhelming. The harmonics that's in the track is muted. That's why tubes will sound good because it will emulate (poorly) the harmonics that's embedded in the track.
Also, have you covered all open ports in the rear of the Dave and other devices? It'll help peer though the music as it reduces the noise. Also when doing HP listening out of the Dave, that will require unplugging the line out connections to cover the ports for that added edge in performance.I am intrigued. Plus @edwardsean said he liked them too, and he uses a DC4 as well I think. I need to look into the src dx more tomorrow.
Might as well jump in with the Topping d10s as well. I think it's lower distortion but has a slight cut in the mids. It'll take at least full 5 days to break in both.I am intrigued. Plus @edwardsean said he liked them too, and he uses a DC4 as well I think. I need to look into the src dx more tomorrow.
That sounds crazy, though I’ve never tried Topping’s productsMight as well jump in with the Topping d10s as well. I think it's lower distortion but has a slight cut in the mids. It'll take at least full 5 days to break in both.
It's annoying why it was still giving that signature Topping sound despite being only a ddc. Lol.That sounds crazy, though I’ve never tried Topping’s products
Fairly obvious it's a form factor issue and a need to fit an aesthetic in mind. The real bragging rights goes to anyone who can make a psu upgrade that can fit inside the Chord chassis.I'm pretty sure that folks at Chord do monitor this thread and are aware of these new esoteric power supplies and that they will do some testing with them. And, if they are indeed worthy, they will be incorporated into new designs, I reckon.
Here's the OTHER catch I'm experiencing. Loud masters that uses limiters can get fatiguing. This is the other issue in my current end game journey that's been bugging me. Mixes that uses limiters has too much sonics that plateaus that it's almost like a flat tone bombarding the ear and it's more evident on TOTL smooth, linear, transparent setups. With that, maybe a tube amp can give more variability and assist it to be more palatable. But this has nothing to do with needing more power on a Susvara for example and may still not be an apparent issue when doing USB inI am intrigued. Plus @edwardsean said he liked them too, and he uses a DC4 as well I think. I need to look into the src dx more tomorrow.
My SQ findings EXACTLY, using a non DC’4d mDave / Euforia AE, with HD800S & Utopia’s.So, I spent another afternoon and evening listening to my TCs straight out of my DC4’d mDAVE. Let’s put aside why it’s working for a moment and just discuss the sound. After further experimenting with the Dave driving my TCs, I’ve noticed some new things. 1) The DAVE/TCs combo is more unforgiving with poorly recorded material compared to my WA33. 2) After several hours, the sound became a little fatiguing. 3). The TC mids are worse out of the DC4’d DAVE. 4) The TCs have higher resolution out of the DAVE, which some would probably like. 5) The DAVE is somewhat clinical compared to my WA33, where strict accuracy seems to be the goal (it is a solid state though). 6) I like the “distortion” my WA33 and tubes bring, though I know some might prefer the more analytical and clinical DAVE.
