A number of people (Rob included) have said in the past that DAVE requires no warm-up time (or even burn-in time). I've found this not to be the case.I've noticed consistently that the Dave needs 24 hours minimum warm up time. The other indicator is it should be warm enough where hovering my hand above the chassis , I should feel the heat wave. If it's a bit under, Susvara can sound peaky and strident. It's something worth mentioning when doing meets to compensate for a cold Dave.
All my hifi is put into standby overnight. From "cold" immediately after standby, I find that DAVE sounds a touch dark, which helpfully hides a multitude of HF sins, which is not unpleasant, but it also hides a level of fine detail. Over the next hour it swings into a slight over-brightness and then gradually settles down. There are other variables when listening over a long period, but I'm satisfied that I can hear no further improvement after around 5-8 hours. This effect is more subtle than other hifi components I've owned, but it's enough IMO to unbalance a well-balanced system.
Regarding listening levels on my DAVE > HEKse, this is set between -40 to -42dB for most modern recordings. Max of -43dB for the loudest ones, and min of about -30dB for the quietest classical recordings. I've measured this with a soundmeter to be in the 70 to 75dB range at my ears. At meets, I cringe when I see how loud some others set their listening levels. I politely say something like "Wow, that's much louder than I'm used to". When what I really mean is "You are a recklessly stupid fool. You should be old enough now to know that this will eventually permanently damage your hearing". Anyway, I agree with the comments that listening volume is a big factor in peoples' differing reactions to the same hifi equipment.
