Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
post-15445685
Post #14,881 of 15,647
ubs28
Yes you need additional software built into the playback software to decode the MQA compression. The alternative is to use another streaming service such as Qobuz which streams high resolution natively without the need for any additional decoding or conversion.
Ok thanks. I will switch over to Qobuz then after my trail of Tidal ends.
Reactions: Peter Hyatt
post-15449050
Post #14,883 of 15,647
keithmarsh
London
London
Hey all! I’ve just experienced and issue where my Poly was low in power (red flashing light) so I turned it off and charged it over night. The following morning Poly won’t turn on at all. The battery indicator won’t illuminate when you connect it to a charger. I left it a couple of days in case it needed to discharge but it is still totally dead. I have tried charging it separately from mojo too. Mojo will still charge through Poly though.
Is this a known issue? Is there something I can do to bring Poly back to life? I had a look through the forum but might have missed something?
post-15449595
Post #14,884 of 15,647
miketlse
Sounds unusual to me. Email support@chordelectronics.co.uk and see what they suggest.
post-15450003
Post #14,885 of 15,647
phurly
PNW
PNW
I am also in the trial period with Tidal. Last night I signed up for the trial of Qobuz and am now able to listen to 96k /192k wirelessly. Sold! I contacted Tidal and told them I am signing up for qobuz and explained my reason why. I hope they catch up.
post-15450309
Post #14,886 of 15,647
keithmarsh
London
London
post-15453211
Post #14,887 of 15,647
Solsticemuzix
SouthEast, USA
SouthEast, USA
I previously posted about my Poly always searching for Wifi even when it’s turned off. Anybody know of a fix for this? Blue and green Wifi search lights are always flashing or active on my Poly; killing the battery I’m guessing.
post-15453318
Post #14,888 of 15,647
Matt Bartlett
Member of the Trade: Chord Electronics
Maidstone
Maidstone
Website
www.chordelectronics.co.uk
Is your Poly plugged into the charger or is this when it is running on battery only and Mojo is switched off? When on charge Poly is always on so that it takes less time to boot up when you switch Mojo on. This doesn't affect the battery life as once it reaches full charge the battery charging stops.
post-15453714
Post #14,889 of 15,647
pwncake
same issue. Onlydifference was that I waspressing The config button to enter into hotspot mode, and the poly just died on me. Now the led just wouldn’tturn on no matter what. I’ve tried draining the mojo and poly connected and recharging it. Tried 1A 2A chargers. It just won’t turn On.
I reached out to the support email and after a few questions, the staff simply pointed me to the dealer to get it checked out.
Which sank my heart because I am in Malaysia and I don’t know where I can go to seek for assistance. I bought the poly in Japan from an audiophile (was working perfectly fine for a week).
Completely disappointed.
post-15453769
Post #14,890 of 15,647
Matt Bartlett
Maidstone
Maidstone
Website
Can you try this.
Disconnect Poly from Mojo. Then with Poly on it's own plug the micro USB charger cable in. Leave it for 5 seconds then unplug the cable and then plug the cable back in. Leave it like this for up to 6 hours to see what happens. It could just be a really low battery that needs conditioning first.
post-15453969
Post #14,891 of 15,647
NYanakiev
London, UK
London, UK
WOW- switching between Roon and Everything Else mode no longer requires Poly to restart!! How awesome is this?!
Loving the Poly-Roon experience overall- well done @ChordElectronics @Matt Bartlett
I can only imagine how good 2Go for Hugo 2 will be.
Reactions: smaragd
post-15454046
Post #14,892 of 15,647
miketlse
If you check the photo in this post it mentions 'for Hugo 2 and more'.
Does this mean the 2Go will work with other Chord dacs if one uses a cable?
Hopefully we will find out soon.
post-15454078
Post #14,893 of 15,647
NYanakiev
London, UK
London, UK
Interesting. In all honesty, with Poly so good, I would hope 2Gogoes above and beyond what Poly does.
Hugo 2 isn’t portable enough to justify a 2Go purchase that enables the same/similar functionality as Poly. I am very much used to listening to H2 in desktop mode.
I look forward to the announcement!
post-15454172
Post #14,894 of 15,647
pwncake
Can you try this.
okay I’ll try it. I just tried Charging it for 8 hours (separate from the mojo). The poly itself is warm,but it’s still not turning on. I tried the 5 second method you recommended but there’s still no light. I’ll leave it for 6 hours and see.
post-15454603
Post #14,895 of 15,647
jarnopp
I don’t recall that this ever required a reboot ??
Users Who Are Viewing This Thread (Users: 2, Guests: 7)
