Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
post-15431038
Post #14,836 of 15,001
Gr8h8m
Fwiw I use Poly for just this purpose (checking WAVs of mixes) but I use M.A.L.P (mpd based). It works great - all apart from the tiresome wait for reindexing the card. A suggestion would be to have a separate small "scratch" SD to use just for quickly checking stuff as otherwise the wait is interminable. I know that's not connected to your scrubbing issue in bubble however - just a friendly thought!
Reactions: phurly
post-15431171
Post #14,837 of 15,001
joshnor713
Seattle Area
Seattle Area
Can we get an update on Google Casting? Is it dead in the water?
post-15433968
Post #14,838 of 15,001
Solsticemuzix
SouthEast, USA
SouthEast, USA
Anybody know which data Poly uses while in AirPlay mode, when away from your home WiFi network; hotspot or LTE data? I check my Verizon wireless Unlimited data plan daily, but I don’t see any hotspot usage, just LTE data. My hotspot is limited to 20 GB’s per month, so I’m guessing it’s just using my unlimited LTE data plan while in hotspot/AirPlay mode. Dunno.
post-15434218
Post #14,839 of 15,001
Utterchaos23
Brighton UK
Brighton UK
I discovered something this morning that may help anyone having battery/charging problems. Having invested in a decent 2.6A charger I was annoyed to see that both Poly and Mojo lights were still not white-charging at the same time and one would flash.
A change of USB cable and now they are both solid white. Apparently USB cables are amp rated!
This may be old news to some but hey at least I know my Polly’s ok!
Reactions: ZappaMan
post-15434269
Post #14,840 of 15,001
ZappaMan
Pyongyang (camp 82)
Pyongyang (camp 82)
Does the supplied usb leads come with white writing on them quoting this kind of info...
post-15434273
Post #14,841 of 15,001
MaxD
well my supplied cable has this in white: "(UL) E305668 Type CM 75 oc CSA" and that is all. No idea what it all means :)
post-15434278
Post #14,842 of 15,001
ZappaMan
Pyongyang (camp 82)
Pyongyang (camp 82)
ok from memory I thought I remembered a voltage being quoted on them or something like that
post-15435050
Post #14,843 of 15,001
phurly
PNW
PNW
Hi @phurly Let me investigate why this is happening. I can also see the same behaviour but only with WAV files.
@Matt Bartlett I discovered that FLAC is the way to go when exporting songs from a DAW. I'm able to jump around within a song and Poly doesn't restart the tune or skip to the next like it does with WAV. Plus artist name, album title and song titles also show up in the MPD. Stoked!
post-15435310
Post #14,844 of 15,001
ubs28
If I use mconnect and use my Tidal account inside mconnect, it for example tells me that the music is played at 48khz @ 24-bit.
However Airplay is limited to 44khz @ 16-bit I believe. So what sound quality am I getting with the Chord Poly?
post-15435511
Post #14,845 of 15,001
jarnopp
You should be getting 24/48k. What color is the sample rate ball?
post-15438797
Post #14,846 of 15,001
miketlse
Similar experiences were reported on the Mojo thread.
Not all USB cables comply with the USB standard - some contain wires with too high a resistance, causing the charging current to drop below the required level.
Changing the cable usually remedied the situation.
post-15439563
Post #14,847 of 15,001
Maidstone
Maidstone
Website
www.chordelectronics.co.uk
Thanks for letting me know. Yes everything is ok with FLAC and other formats. We are still investigating WAV as it works with some players but not with others.
post-15439708
Post #14,848 of 15,001
music4mhell
@Matt Bartlett Any updates on chromecast support ?
Now Amazon prime also supports it :D
post-15439717
Post #14,849 of 15,001
Utterchaos23
Brighton UK
Brighton UK
Hi All.... what’s your favoured iOS app for controlling your Poly?
I find Glider cumbersome and confusing.... (use MPD or Poly as server?... keeps Re-syncing) and 8player destroys gapless albums..
Lesser of two evils!
post-15439722
Post #14,850 of 15,001
Cubass
Poland
Poland
Rigelian - very simple, good to play from SDcard
mconnect - to stream
Users Who Are Viewing This Thread (Users: 5, Guests: 8)
