Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
962 963 964 965 966 967 968 969 970 971
973 974 975 976 977 978 979 980 981 982
  1. PrittiPoly
    The train fare was probably cheaper than the battery.
    ZappaMan likes this.
  2. Amberlamps
    Probably, as the train is powered by slaves and he has millions of them.
  3. Vyyy
    @Matt Bartlett are you and the Chord team attending Salon haute fidelite show in Paris right now?
    Thaks!:)
    Peter Hyatt likes this.
  4. Matt Bartlett
    No I’m afraid not. It’s unfortunately a case of too many shows all on at the same time. Our distributor will be attending though.
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    Vyyy likes this.
  5. jarnopp
    Hi Matt,
    I can’t recall if this has been suggested before, but would it be possible to add a crossfeed feature to Poly? Maybe 3 levels using Rob’s code that could be set in GoFigure (so that it would work with streaming as well as SD card playback).
    Does Poly have enough horsepower for this?
    Thanks!
  6. Matt Bartlett
    Hi,
    I'll add this to the discussions. However I'm pretty sure the crossfeed function is part of the FPGA core code so effectively it is a hardware function that could not easily be translated. If it is possible then yes Poly does have the horsepower
    to process a function like crossfeed if we could implement it.
    jarnopp likes this.
  7. Sound Eq
    can i ask how is the sound quality compared to wired when I will use ploy with mojo using bluetooth
    i see the bluetooth used in mojo is not the best there is, so compared using mojo wired vs using it via bluetooth with my iphone what shall I expect ?
    my plan is to use tidal streaming on my iphone using bluetooth and mojo+poly on the go when there is no wifi access
  8. Progisus
    Poly in hotspot mode would provide the best sound quality if there is no wifi avaialble.
  9. Sound Eq
    yeah but that will consume lots of mobile data
  10. Progisus
    No data. Poly makes wifi that phone connects to. Then you can play whats on the card.
  11. Sound Eq
    i don't know if i correctly understand the whole thing, is there a video i can watch
  12. Progisus
    If you Google "chord poly hotspot mode" there will be multiple choices to help you. Poly hotspot mode will not allow any streaming services, only access to play the card using something like mconnect.
  13. joshnor713
    Could use a little help. Got a new phone and it won't connect to the Poly's hotspot network via wifi. Just sits on "obtaining ip address" and isn't able to connect. I tried my wife's phone and my PC and same thing. The only device that can connect to it is my previous phone. Any idea on why this is happening?
  14. supervisor
    try removing all saved wifi SSIDs and start over
  15. joshnor713
    How?
