Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
post-15146423
Post #14,161 of 15,462
ZappaMan
dynamo hum
dynamo hum
post-15146758
Post #14,162 of 15,462
PrittiPoly
Upper Tree, UK
Upper Tree, UK
The github page says
  • Devices - enables copying from/to USB-Mass-Storage (UMS) and MTP devices, and ripping AudioCDs
So I’m thinking it may support pc to poly file copying ....
I don't think there is a way of getting Poly to show up as a UMS or MTP device, so only possible to copy playlists from an MPD client. Happy to be proved wrong.
post-15146774
Post #14,163 of 15,462
smaragd
Asia
Asia
Cantata Mac user here...
writing playlists to mSD card yes
moving files to mSD card no
Reactions: ZappaMan
post-15147030
Post #14,164 of 15,462
Gr8h8m
You can't transfer files with it in situ. Gotta do it externally from Poly then reinsert and wait for it to rebuild it's database while flashing it's disco lights (and if you've got a larger card it could take quite some time)
post-15147444
Post #14,165 of 15,462
Daniel Johnston
Same here. I’m trying to track down what’s messing with my dlna and mpd database. I’ll occasionally find albums missing from dlna and consequently the mpd database. It’s usually the same couple albums. Refreshing the databases doesn’t work. I put the microSD card in the Mac and the albums are there and intact. It started when using cantata. Deleting the database files always solves the issue.
post-15147448
Post #14,166 of 15,462
smaragd
Asia
Asia
Another tool I use is Yate to check and fix metadata. So far all files and albums show up correctly. I rip to FLAC and DSD so my library exists of these 2 types of files.
post-15149480
Post #14,167 of 15,462
Matt Bartlett
Member of the Trade: Chord Electronics
Maidstone
Maidstone
Website
www.chordelectronics.co.uk
@Matt Bartlett are you able to offer any advice?
Apologies for the late reply. It was a holiday weekend here in the UK so I've been away.
I see that this has mostly been answered. At the moment no you can't directly copy
files to and from the SD card whilst in Poly.
However it is possible to see and play the music stored on the SD card whilst in Poly
using J River MC as Poly will just appear as a DLNA/UPnP server.
post-15150034
Post #14,168 of 15,462
headmanPL
United Kingdom
United Kingdom
post-15150054
Post #14,169 of 15,462
ZappaMan
dynamo hum
dynamo hum
Reactions: PrittiPoly
post-15150759
Post #14,171 of 15,462
ZappaMan
dynamo hum
dynamo hum
Reactions: Peter Hyatt
post-15152055
Post #14,172 of 15,462
Vyyy
Europe
Europe
I'd like to report issue with GOFigure quick play playlist show. Problem is that after i load refresh playlist and scroll down up and switch between them it always happens that some playlists are playing not the tracks inside them but completely new playlist. In short - playlist names messes up. Also total amount of playlist also is getting lost. I have each time to reload playlists. After few of them got played i cant find my playlist which is simply gone from list. Again reload does job...
I think Gofigure on next update needs to sort this out. Its annoying and takes extra time from user.
@Matt Bartlett Thank you very much for readresing this issue if its unknown.
post-15152067
Post #14,173 of 15,462
Matt Bartlett
Maidstone
Maidstone
Website
This isn't a known issue or at least I have not been made aware of anything like this. It sounds like your database file might be corrupted. Are you able to delete all the database files from your SD card and then put it back into Poly and let it rebuild the database. You will see the P status light flash multiple colours to indicate the database rebuild. See if that fixes the issue for you.
post-15152072
Post #14,174 of 15,462
Matt Bartlett
Maidstone
Maidstone
Website
post-15152144
Post #14,175 of 15,462
Vyyy
Europe
Europe
I tried to delete mpd file and then put again to poly but it instantly flashes green light for a fiew secoonds and in general settings i see mpd playlists total songs and status dlna dba - idle. Refresh does not put it to indexing mode. How to force to reindex?
Users Who Are Viewing This Thread (Users: 2, Guests: 5)
