ksalno
- Jan 17, 2017
+1 on successful update. I had already removed the SD card and was already running 1.41, so I assumed I could go straight to the Update Firmware step but needed to power off/on, reconnect Go and then was able to do the firmware update in 10 minutes.
As for the question on Roon, I went with Poly, since that is the RAAT device and Mojo is the DAC which is downstream from Poly from Roon's perspective. It works fine that way.
