That's true if your main source of music is from online. However, if you have tons, and I mean multiple GB's of ripped music in ALAC, AAC or MP3 format, that you simply have no choice but to find the room on your iOS device to store them, then the iPod Touch is a great choice. I know, the microSD card slot on the Poly is potentially going to give you another option, but what's unknown so far is how you will organize the file structure on it so the app for the Poly will recognize all its contents. Most likely, the filing structure is going to be different from your iTunes library, so there is going to be an initial effort of copying the music stored on your iTunes library to the microSD card, organize it the way you want it, and then there is the ongoing maintenance aspect of when you add music to your iTunes library then you need to copy it over to the microSD card as well. In other words, there is going to be work flow problems to be solved. Furthermore, how are you going to port your playlist data to the microSD card and the Chord Poly app? This is still up in the air.
