Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
808 809 810 811 812 813 814 815 816 817
819 820 821 822 823 824 825 826 827 828
  1. MaxD
    Me too, thanks Mike, I didn't know we could ignore trolls :), guess who was my first …..
  2. PrittiPoly
    Looking more closely at your avatar, I think you have probably voided your warranty.
  3. TangoMan
    Poly still not working. All seemed to fudge up yesterday when I was on site. I wonder if my phones hot spot was to blame. Anyway roon was disabled and then go figure crashed.now I can see it on the home network but have no bluetooth conne tion and therefore cannot use gofigure. How do I connect to it?
    MALP is unable to connect to it on my local wifi
  4. TangoMan
    Blue light stays on for 30 seconds, then off for 10, on, off, and then on for 30. Keeps cycling through this.
  5. PrittiPoly
    Have pin will travel.
  6. TangoMan
    Yup, tried that immediately, no voice through earbuds at all.
  7. headmanPL
    I've not experienced that situation. Initially I thought that "forgetting" Poly in your Bluetooth phone settings, then reconnecting might help. Then reading about the blue light cycling, I'm not sure it would do anything.
    It may be worth logging that directly with Chord support to see if they can help.
    TangoMan likes this.
  8. PrittiPoly
    Probably totally irrelevant but I have just updated my phone from Android 7.0 to 8.0 and GoFigure no longer connects although phone appears to be connected to Poly via Bluetooth.
  9. TangoMan
    Was updated a couple of weeks ago, to Android 9 and its been fine. I've got a feeling it started updating over my mobile hotspot and then got interrupted. Will raise a fault tomorrow but real shame as its become an integral part of me getting through the day (earbuds in as I polish cars). Got the latest album by The Cinematic Orchestra and having to slumb it listening to it on vinyl :D
  10. miketlse
  11. TangoMan
    Will leave the poly on charge tonight separately and see if that helps. If not I can pop over to Nintronics tomorrow where I bought it from. Thanks for the feedback guys.
  12. vkvedam
    @Matt Bartlett
    With this new firmware and the subsequent GoFigure update is it possible to browse through the SD card using the app in Airplane/Flight mode? We can do away with this WiFi scanning chirping noise etc as a result.
  13. Matt Bartlett
    Yes I can confirm that when your WiFi isn't connected then you no longer have the chirping noise using Bluetooth audio or Quickplay.
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    JedG, vkvedam, fordski and 1 other person like this.
  14. vkvedam
    Did you answer my question?
    Sorry to be a bit naive :)
    Can we browse the SD card for files using Gofigure after the update?
  15. Matt Bartlett
    Ah sorry I thought you were just asking about the WiFi scanning. No as I mentioned before GoFigure uses Bluetooth BLE which is only able to send a few Kb of data every few minutes.
    This means to browse an SD card containing several thousand music files would take hours to download the album/tracklist into GoFigure. It just isn't practical to use BLE to browse SD card content which is why we limited it to playlists only as the fastest option. Having said that Bluetooth is constantly evolving so as the BLE format develops there is possibility for it
    to become faster and then that would give us something to work with.
    ag18, zenlisten and vkvedam like this.
