vkvedam
That's very strange!Fwiw installed fine here.
I don't know if it helps but I had to open the APK from within the phone's onboard Files app. I tried directly from Chrome and got an error.That's very strange!
Worked! I shall report back.Ok. Can you PM me your direct email address and I will try sending you the file directly to see if that works.
I think my biggest irritation with GoFigure, possibly even greater than non alphabeticized playlists or not displaying playlist contents is the fact that opening GoFigure halts MPD playback (haven't checked on uPnP yet) - it's just absolutely maddening! I just don't understand why it would want to sabotage the user experience of it's core functionality.
My poly has a solid blue light. It won’t connect to the go figure app and seems locked up. I’ve thought I’ve heard of this before, but need some guidance. Solid blue light has been on for almost 10 hours. Is it bricked, or will it eventually shut down and then reconnect after charging?
Help, please.
Scott
The Qobuz app on iOS can stream offline via AirPlay only. So would be limited to 48kHz. The MacOS app can do DLNA and hires to Poly.I have been considering purchasing a subscription to Qobuz. Is it possible to stream Qobuz offline content from iPhone to Poly? Can this be done with high resolution audio? Or would one use AirPlay?
Hi Matt, this new app update is a good one, it detects and connects to the Poly without fail. And it does connect to the Poly even when it's already on the WiFi network.Hi @Gr8h8m. Just to understand is then when using the Quickplay function? It doesn't happen on iOS GoFigure so we will check what is going with the Android version.
