Gr8h8m
- Jul 11, 2005
Does it index the card (doing the disco light dance) when you turn Poly on?Yes, I can see folders and files on the PC.
Ah, that must be it. I don't see the db file and i don't think it's indexing. Can I force that manually?Does it index the card (doing the disco light dance) when you turn Poly on?
Also, verify that your replacement has the latest firmware.
Guys, thanks for your replies. I don't see how to verify my firmware. I went to the bottom of the config page, but ... nothing.
I do not believe that glider has access to be able to write its own stored playlist as these files. (Could be wrong - @joe28 )
Firmware version: 1.0.6. Should I have a later version?and what version of firmware did you end up downloading?
