Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
446 447 448 449 450 451 452 453 454 455
457 458 459 460 461 462 463 464 465 466
  1. Amberlamps
    I just pulled the trigger on Hugo 2, I hope it is as good as they say.
    It will be used mainly as a static system and mojo for ugh, whatever.
    NaiveSound and PJDubyaM like this.
  2. Muzslya
    Oh my God I didn't realize that we are dealing with gods here.
    It's time for me to be serious and go back to my game (Angry Birds)
    Laslo
    NaiveSound likes this.
  3. PJDubyaM
    I've not read about Spotify integration in a while. Apologies if I've missed it. It's in the manual as a thing that the unit should have. Any updates please, Chord? At the moment, when I want to do a try-before-I-buy on an album (which generally what I use Spotify for), I just hoik my headphones out my Mojopoly and pop them straight into my laptop. First-world problems, I know, but it's not why I've got a grand's worth of DAC sat on my desk. Thanks!
    [EDIT: good lord, music piped straight out my laptop sounds awful. So that's why I've got a grand's worth of DAC sat on my desk! Like others in this thread – lusting after a Hugo 2 at the moment. But waiting until I've got funds for that and a pair of Focal Clears all at once.]
    Mightygrey and headmanPL like this.
  4. ryanhart72
    I am a new Poly owner and my experience has been okay thus far. Working well on home WiFi, no success setting up a personal hotspot for travel. Question - loaded SD card with a couple hundred GB of music and installed in Poly. Gilder recognized and synced with Poly. None of my HD tracks files show in Glider. I also frequently see a timed out response. Suggestions?
  5. PJDubyaM
    First check: you've got your SD card formatted correctly? Needs to be ExFAT I think (first time I tried it, it didn't work, for precisely that reason – daily driver is a Mac, which half-explains it).
  6. styks
    Edit missed quote.
  7. TKpurple
    Check if HD tracks did not landed in the unknown folder in Glider. Contact Joe28 from Glider - he is very responsive and helps with the issues. Also check if you run latest Poly firmware (ends with 1.0.17).
  8. styks
    Ive not had a go at you ever, ive not insulted you or Chord, admittedly i may have had a laugh at your expense but that's hardly having a go is it? I take issue with you talking about CANCER and WAR when talking about a guys getting annoyed with Chord. I didn't mention violence you did. You should think when you type, what the hell has CANCER and WAR got to do with these discussions. I've know men like you, man up and apologise. ..... You can post and think what you like, of course you can, but keep words like that out of your comments! .... You insult and hurt people who've had first hand experience of Caner and War, Ive seen War and the oppressed and done my bit to help them, have you? ....... I'll reply no more, so write as you will but if you start behaving and commenting like that again, just because you get angry I'll report it. Have some respect, Its inappropriate and wrong, and you know it, which is why you reply so agressively.
    As I said reply as you will, I'm done with you, NOT Chord, just you!
  9. ryanhart72
    There is an unknown folder, full of tracks. Will check them out an contact Joe.
  10. TKpurple
    You can stream spotify to Mojopoly over wifi or using telephone hot spot mode over Airplay using spotify app. It works flawlessly for me (the most stable connection and no issues with finding mojopoly as rendered in airplay). Spotify connect is in the manual and should be probably incorporated in the Gofigure app at some stage but I do not remember it being mentioned recently as part of the Gofigure app upcoming ability.
    PJDubyaM likes this.
  11. BluebirdCRM
    I believe Chord has been open from the start about 3rd Party development. If you wanted an app from Chord built from the ground up the price of Poly would be higher. Software development isn't cheap. UPnP/DLNA is designed
    This is how Apple works. They approve every app and sometimes require more testing when networked hardware is involved. I know this as I have worked with other companies like Auralic and Naim who have built UPnP/DLNA products with apps.. They have had to go through the same process and everytime there is a redesign of the app they have to go through the process again.. This is normal behavior from Apple with these kinds of App's. Flatulence App's may be treated differently.
  12. huangwan
    I think it would be wise of Chord to open up GoFigure to a beta. Not necessarily me but some of the more savvy user here. Jeremy L.( sp) comes to mind along with some others here. Things that might be caught by Apple (if that is indeed where the app is) would be caught, and we could FINALLY GET THE FREAKING THING. They could PM the candidate and do a NDA and use the legion of invested people they have.
  13. BluebirdCRM
    Hello. There are two different kinds of Bluetooth one is what we have all been using to playback audio with. The other is called BLE. This is what GoFigure is using not the crappy bluetooth you are describing. Also Chord I don't think has ever described GoFigure as a full playback application. From my point of view they have always described its has limited playback capability which is why we focused on other apps like 8Player, Glider, Bubble etc.... The point of GoFigure is to allow you to change the configuration of Poly very easily and without the Sim Card Tool. Its very nice to be able to switch back and forth between Roon and Other Modes or Hotspot to WiFi mode or to just hop into it and tap a playlist. Really it changes the experience quite a bit for me.
  14. dontfeedphils
    As far back as I can recall they've touted "GoFigure" as having SD playback control. Another broken promise it seems. Now I'm really not going to be an owner of a Poly. Time to start looking into nice DAPs, sell off this Mojo.
  15. StevieDvd
    They did make an offer but it has not been realised here, the first we have heard of it is from @BluebirdCRM who is a dealer/distributor of Chord I believe. Some of us here are in the software industry and have been testing for years so a beta would not faze us. Though I do tend to find a lot of defects which might delay the app so I'll hold back and submit the when it's officially released.
