You welcome. Let’s hope Astell & Kern don’t read this thread and block the Poly
Which of the AK Connect apps are we talking about again? I have found two so far
I've noticed that the Poly's audio glitching is connected to it scanning WiFi networks. As an experiment I setup a playlist to play using M.A.L.P, set it playing and then turned my phone's WiFi hotspot off. It played through the whole playlist (as I was hoping - without needing Phone or any other WiFi connection) but glitched every few seconds as it scanned around for a known network to connect to. I'm guessing the Poly WiFi radio needs a firmware/driver update so that actual audio streaming can be prioritised and not disrupted by networking shenanigans.
That's great news Matt - I was hoping for a WiFi on/off switch in GoFigure. My ideal situation would be WiFi switchable on/off with full Bluetooth playback control of SD files. GoFigure can't come quickly enough!Yes Poly is always scanning so that as soon as a known network is available it will automatically connect rather than manually having to prompt Poly to reconnect each time. However we have added an Airplane mode into the GoFigure app. In your scenario above you
can use MPD and set a playlist running whilst on WiFi then activate Airplane mode through the app so that the WiFi in Poly is disabled and it will stop scanning. The music will continue to play until you get to the end of the playlist.
AK Connect was last updated tp 1.3.9 a year ago... Ak Connect 2.1.0 was last updated a month ago and supports Tidal ServiceWhich of the AK Connect apps are we talking about again? I have found two so far
When I’m in tidal and I choose an output for the audio, I see poly (given my specific name. ”mdp” and displayed as a speaker ) and also a blue tooth poly - called ‘poly’ with a Bluetooth icon.Just tried the ak connect app. And I’m streaming Tidal HiFi direct to poly as renderer . And it’s very stable so far. Before I didn’t know iPhone can stream tidal direct to poly apart from with airplay.
This is direct streaming to poly without going through airplay. I’m excited to found out this.
When I choose mdp- is that tidal streaming directly to poly - by virtue that we all are on the same network - and not using Bluetooth/airplay (even though it shows up as a type of airplay device?)
Poly in wireless client mode should do
What about android phonesAirplay. Phone as personal hotspot with poly as client. On Tidal app, you should see Poly on the Airplay list
