Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
235 236 237 238 239 240 241 242 243 244
246 247 248 249 250 251 252 253 254 255
  1. NYanakiev
  2. Mountain Climber
    @jldevo - I have the same with mine - I think there were a couple of us that saw this in the first week after release. Pretty sure mine is also a dislodged light pipe as suggested by @Mojo ideas earlier in this thread so it needs to be returned to Chord have it popped back into place. Doesn't cause me any issues not seeing Mojo's power status indicator but will return at some point during the warranty to get it fixed - too busy enjoying the music right now! And I'm not as brave as @Andreeas1978 !!
  3. Mojo ideas
    We know that part of the testing procedure checks the pass through illumination so we can certainly hope that they are fine on shipping out
    but we are assuming that when the configure pin is being used that it is sometimes being inadvertently inserted in the wrong hole and it is pushing the light pipe out of position I know this can happen as I’ve done it myself. Fortunately when the Gofigure App is released later in this month the configure pin can be consigned to the trash can where it belongs as the app will handle this.
  4. Andreeas1978
    Mine had the pipe dislodged at the Mojo end, not black window where it could be confused with the reset hole. Actually during assembly it tends to stay ok in the plastic window and jump out of the triunghiular-ish larger Mojo hole!
  5. Andreeas1978
    Pls take a look and tell us which hole does not have the light pipe coming out like a tiny LED
  6. Andreeas1978
    And no, Sir, I don't put the wrong tools in the wrong holes, I mean it! That could have costed me my life back in Afgh, I am EOD specialist (explosive devices)
    And the pass through illumination test might get fooled by the fact that a bright enough light still comes through Poly's body like through a simple box, as first tested with my phone flashlight.
  7. jldevo
    The light pipe is sticking out a few millimetres at the poly end. The elongated hole at mojo end is empty. No sign of any light pipe. Not sure how it should look. Anyone got a pic of the light pipe at mojo end? Or a pic of what I should see at poly end when m. Status works correctly? Thanks.
  8. Andreeas1978
    This is just a minor...fact, I don't even consider it a problem.
    Yep, that was my case also! I don't have pictures from before fixing it but I will upload in just a moment some of how it should look
    Let me just turn it off and take them..
  9. jldevo
    I just tried the torch of my phone. The m. Status illuminated white. Why doesn’t it illuminate with mojo led? Maybe the phone torch was much brighter, thus enough to work.
  10. jldevo
    @Mojo ideas I can guarantee I have not used the config tool in the light pipe area. My light pipe is visible and sticks out 1-2 mm at poly end.
  11. Andreeas1978
    Mountain Climber likes this.
  12. Andreeas1978
    Kinda hard to catch with my phone. At first, box sealed, the connections side hole was just an empty triangle. That's where the pipe takes its light from Mojo. At this end, the pipe stays loose, easy to escape during factory assembly and a pain to keep in place during manual assembly.
  13. Andreeas1978
    YES!! That felt strange to me too, l remember! coming out a little at Poly end!!!
  14. Andreeas1978
    Be careful not to have it out even more and crack it, it seemed kinda brittle to me and the length is exactly calculated from hole to hole.
  15. rkw
    WiFi channels 12 and 13 are actually allowed in the US, but transmission is restricted to low power to avoid interference with adjacent bands. Something else to consider is that the devices might have a location derived from cell connection, IP address, GPS, etc. E.g. music apps need to determine location (country) because of licensing agreements.
