Chord 2Go & 2Yu Wired/Wireless Network streamer and S/PDIF adaptor - Official thread
Superpong
- Aug 2, 2007
Hi I just have 2Go connecting Hugo2 recently and I select “Build Playlist” in Gofigure app. The process is very long and still running (longer than 10hrs) as shown in the picture. Is this normal? Is it because the microSD has too many songs? (Approx. 190GB)
priest331
hello,
do the replacement batteries for the hugo2 have longer duration per full charge than the old ones?
mine lasts around 6-7hours. my hugo2 batteries die out earlier than my 2go, at which it still has around 50-70% charge left when the music stops playing. thanks.
Superpong
- Aug 2, 2007
I always connect a powerbank to Hugo2+2Go in order to enable the desktop mode but I observe that 2Go always turns back on even though I switch off 2Go. Therefore, 2Go always drains power from my powerbank all day long.
Is there anyway to force 2Go to shut down when connecting to powerbank or a power adapter?
MarkParity
Its far easier to replace the batteries in the Hugo 2 so I simply disconnect the power when not using mine and forgo desktop mode. I don't know if keeping the 2Go powered is bad for the battery though but I don't want to take the risk.I always connect a powerbank to Hugo2+2Go in order to enable the desktop mode but I observe that 2Go always turns back on even though I switch off 2Go. Therefore, 2Go always drains power from my powerbank all day long.
Make sure there is a network connection between your 2Go and Gofigure app. I have close to 1TB of songs and >800 playlists. It takes <10 minutes to index and a few seconds to load the playlist. I don't use the "Build Playlist" function, and I cannot comment on that.Hi I just have 2Go connecting Hugo2 recently and I select “Build Playlist” in Gofigure app. The process is very long and still running (longer than 10hrs) as shown in the picture. Is this normal? Is it because the microSD has too many songs? (Approx. 190GB)
Hi all
Sorry dumb newbie question.
Can I use my phone as a hotspot when out and about to connect Hugo2/2go to the WiFi of my phone to assess tidal and Roon Arc?
Will it keep up with buffering at high quality.
Many thanks
Many thanks
surfgeorge
Member of the Trade: 3D Printed Accessory Designer
I am using iPhones and the iPhone personal hotspot. After registering it with 2Go it will connect, and you can use the phone's internet connection.Hi all
Many thanks
For playback control MConnect lite works quite well, and it supports Qobuz and Tidal.
I use Tidal, but only the Standard subscription since I found Qobuz to provide better SQ even at 16/44 and on top of it Qobuz provides true HiRes data. For streaming via the mobile network you can define the max. quality in the Qobuz settings up to 24/192. (personally I am using 16/44 on mobile network). Tidal is similar except that they don't specify actual bit/kHz values but only their ambiguous proprietary quality namings.
No experience with Roon
Hope that helps!
HeavenlyD
Just for info, I have a Chord Hugo2 + 2Go for sale now in the classifieds if anyone is interested.
https://www.head-fi.org/classifieds...genuine-case-audioquest-cinnamon-cable.35046/
gonzfi
- Dec 22, 2012
Could someone clever advise why the 2go/2yu doesn't play nicely with a NAD M51 dac? Sound is muffled and scratchy through USB and through coax. Both units work fine in other scenarios so I dont think anything is faulty.
MarkParity
It could be digital clipping, I found this elsewhere on the internet, just Google "NAD M51 DAC issues"Could someone clever advise why the 2go/2yu doesn't play nicely with a NAD M51 dac? Sound is muffled and scratchy through USB and through coax. Both units work fine in other scenarios so I dont think anything is faulty.
"There was no evidence of any overload distortion. I should say here, that when I bench tested the M51, if I used a 0 dBFS test signal, and the M51 volume control was set to 0.0, there was some digital clipping. This is common with 0 dBFS signals feeding a DAC, and is why music digital recordings usually don't go near the 0 dBFS mark, but stay at least - 5 dB below that, so as to avoid clipping. However, for really dynamic recordings, including the 1812 where there are special effects such as the cannon shots, I would suggest turning the M51 volume control down to - 1 dB. This will eliminate the digital clipping - if any should occur. The ability to control the volume digitally on the M51 without truncating the LSB is unique, and extremely useful."
Edited December 28, 2013 by rocky500
Heartsmart
Is there some way to turn off Bluetooth on 2Go. Or is it always on no matter the input?
BLE is used for primary control, so BT is always on all the time.
Heartsmart
Thanks for your answer! I thought that maby it was turned of when using network cable in airplane state.BLE is used for primary control, so BT is always on all the time.
Hey guys I just got a 2go and I connected it via wifi on the go figure app.
I want to use tidal, I cant find the music service login page on the app.
What am I missing? I feel really stupid. But I cant find the page when I click on music I just get a list of radio stations.
Total: 6 (members: 0, guests: 6)
