Lots of negativity on here...however, 2Go simply rocks for me.
I haven't regretted buying it for a second.
It's a pity that the situation with the use of Roon has worsened.While reviewing your application, we noticed that your uncertified device didn't ping our cloud certification check before September 21. Because of this, we're not able to grant you developer access.
Sorry friend!
I just got my rejection email yesterday.If its roon integration you're worried about, I think you can still apply for developer status for the 2go with roon. Just explain your situation to them. I'm sure they'll help you out.
I believe that they verify you had the 2go on Roon prior to the deadline. So if you bought new, you're stuck - unfortunately. But if you were using it prior, they can tell and they'll approve. But don't quote me - ask 'em.applied late last week and accepted today.
Doody
All the more shameful that Chord are still advertising it on their website as Roon ReadyI believe that they verify you had the 2go on Roon prior to the deadline. So if you bought new, you're stuck - unfortunately. But if you were using it prior, they can tell and they'll approve. But don't quote me - ask 'em.
Doody
Is identification of 2Go in Roon carried out only by the serial number or is the serial number of 2Go taken into account, as well as the device (computer) with the Roon kernel installed?I believe this is a rather accurate assessment of the situation and who will be granted further access.
For me it was entirely automated. I emailed them. They replied "you're all set!". I gave them no information other than my Roon email address.Is identification of 2Go in Roon carried out only by the serial number or is the serial number of 2Go taken into account, as well as the device (computer) with the Roon kernel installed?
This doesn’t make any sense. If your controller is having influence on the sound, something is set up wrong. No way you need a high end dedicated DAP to get the best SQ. Zero chance.I definitely can hear the difference... Try focus on the vocal... They can sound little thicker or thinner between apps...
Try using different phone using same app to play 2go SD Card will sounded different too...
I'm scared maybe you need good dedicated DAP to control 2go to get the best SQ...
