dreamercross
Are the MEE audio x8s the best wireless iems for chifi at this moment? kind of pricey though
Hifi Boy OS V3Looking for a hybrid IEM with a really rich tonality and decent micro-detail with nozzles that are not too short about $120-$160 max, if anyone has anything that they know off that is not v-shaped....L-shaped best ! .....no treble dominace, even recessed treble is fine...I can get fatigued with treble after a while.
Thanks, I've owned quite a few of the sub-$150 hybrids already and one example being the LZa2 (no longer avail.) was just perfect...trying to get a balance of the micro-detail of BAs with the musical fullness/richness of a dynamic unit.If it were me, based on what you’re saying about recessed treble and treble fatigue etc I wouldn’t even be looking for a hybrid. I would be looking at single dynamics, which I think would give you the best shot at getting the signature you’re looking for.
Other option is to use EQ to cut the treble down, which is the ideal use of EQ (ie cut vs boost).
Someone in the KZ thread just gave a brief description of his....Has anybody had a chance to try the trn v80 already?
BrainWavz B400 available for 159 on Amazon. Worth it ? Or something else under 200 USD ?
This should also help cure the itch
Absolutely worth it. B400 is @#$*ing awesome.
