Chinese / Asian Brand Info Thread (On or Over Ear Headphones)
post-14708006
post-14708023
Post #5,147 of 5,966
Markolav
In your head
In your head
Thanks for the suggestion, but price looks above $300.
What? Where did you looked for them, they are like $90 on Aliexpress. Pretty much a steal for that money imo.
Reactions: Hixbot
post-14709517
Post #5,149 of 5,966
Markolav
In your head
In your head
Wow, I had found a bad link, I think. Thanks, I will jump on this.
Great, feel free to share your impressions here or on a Msur-thread once youve received them.
post-14710292
Post #5,150 of 5,966
Nikostr8
Spain
Spain
any good bluetooth headphones to consider? i know its not the best audio quality but i really want a BT pair.
thanks in advance
post-14710346
Post #5,151 of 5,966
ArgBoston
USA
USA
thanks in advance
I'm not very familiar with bluetooth headphones, but the Bluedio's seem to be very popular.
Reactions: Nikostr8
post-14710459
Post #5,152 of 5,966
slapo
London, UK
London, UK
I've been using the Eksa ES100 for a while now.
(using an image from the Aliexpress listing I got them from)
With the stock pads (which are actually fairly comfortable), the bass is way too elevated and bloated and just not nice. Otherwise, it would have been OK stock. Pretty wide and deep soundstage. Imaging, not that great.
So I swapped pads one them. HM5-like cloth pads instantly improved the sound. Soundstage still wide and reasonably deep. Imaging improved, but still nothing to rave about. Bass got... tighter, the bloat was gone and suddenly it was a fun headphone.
I have also tried SteelSeries Arctis 3 style ear pads and those open them up even further, although I felt it was more like a vanilla vs banana ice cream compared to the HM5-like cloth pads.
Battery life if decent. Funnily enough, one side of the box said 30 hours, the other says 10 hours. :-D
Comfort is nice even stock. Build is decent for the price. Cups a sort of plasticky, but feel pretty good, if a little thin.
I'm prettty happy with the purchase. I might still try modding them a little, putting some dynamat extreme inside the cups maybe to see where I could get them.
Reactions: Nikostr8
post-14710477
Post #5,153 of 5,966
Slater
Cincinnati, Ohio USA
thanks in advance
If you get a Bluetooth adapter, you can use it with any headphone :wink:
post-14710505
Post #5,155 of 5,966
trellus
Plano, TX
Plano, TX
Reactions: Nikostr8
post-14710560
Post #5,156 of 5,966
Kevang
Somewhere
Somewhere
thanks in advance
If budget is no concern, you can try out FiiO's recently released BTA10 for the Audio-Technica ATH-M50X. It basically converts the ATH-M50X (a well-known and excellent headphone) into a Bluetooth pair.
Link:
https://penonaudio.com/fiio-bta10.html
post-14710743
Post #5,157 of 5,966
Slater
thanks for the comment, I have considered this option but i really want a ''free-cable'' pair. Do you have any recommendation?
Well, what I do is use the Xiaomi Bluetooth adapter.
It's the size of a AA battery, has a built in clip, and also comes with a 3” male to male pigtail. The pigtail is perfect for attaching to headphones. It’s so small and lightweight, you can simply let it dangle. Or in the case of the 1More, you can attach it to the headphone with a tiny piece of Velcro (or a twist tie) - it fits perfectly against the side of the headband adjustment slider.
But if you truly want a cable free bluetooth headphone, I have a few pairs of Bluedios. They are bassy and v shaped, but they have long battery life and are pretty good (some models are much better than others).
post-14711638
Post #5,158 of 5,966
Nikostr8
Spain
Spain
do you recommend a bluedio headphone in particular?
post-14711820
Post #5,159 of 5,966
Markolav
In your head
In your head
Ive heard that Edifier is getting ahead of Bluedio in bluetooth headphones. There are mainly positive reviews about them and many of my buddies have told me that they sound much better than Bluedios.
post-14711992
Post #5,160 of 5,966
Slater
Reactions: Nikostr8
Users Who Are Viewing This Thread (Users: 3, Guests: 10)
