As far as i know, not available in tabao yet. But my local forum has an MO going on. At around Sgd$148 ( US$104 ) a pop.
Looks killer for just over $100 USD. Consider me interested. I'll be watching for info on where it can be purchased!
Woody with biodyna and its an open headphone. That the first combination i have seen. Already on the MO list.
Just wanted to send shouts out for your Larry Bird avatar. Born and raised in Boston.... If there is any way I can buy one in the USA I would be extremely interested?
Specification: Frequency:20-20kHz Lmpedance:32Ω Driver Size:50mm Magnet:NdFeB Sensitivity:95dB Cable length:1.8m Audio Jack:3.5mm gold-plated Weight: 180g- This is unbelievable light !!!
If I remember, that's less than MA900 weight, which would mean either this is smaller than I expect, or it's truly light weight. Either way I'm curious.
No they're light weight porta pro equivalent in terms of sound. Come with really nice cusions. They used to make a vmoda clone called LP2 but I've not heard that. https://www.aliexpress.com/item/Original-KZ-LP3-36MM-Dynamic-Noise-Lsolating-Super-Bass-HIFI-Monitor-DJ-Stereo-Music-Headband-Computer/32648980251.html?spm=2114.30010308.3.17.nXSjzh&ws_ab_test=searchweb0_0,searchweb201602_1_116_10065_117_10068_114_115_113_10084_10083_10080_10082_10081_10060_10061_9999_10062_10056_10055_10037_10054_10033_10059_10032_10099_10078_10079_10077_426_10103_10073_10102_10096_10052_10050_10051-9999,searchweb201603_1&btsid=6b7fa630-d7df-4cd4-8852-693175611b47
Clearly that's not a normal/functioning pair of Yenona's. If you're able to, I recommend you return them for exchange. My first pair developed a deal left earcup immediately upon 1st listening. I returned them to the ebay seller for credit (I wanted an exchange, but they weren't able to accomodate that). I purchased my 2nd pair for $20 from Amazon and they were fine. Oddly enough, they've become brighter after ~300 hrs of use, something I really don't understand. Am playing around with pad switches &/or fabric lining in earcups to modify the sound--because I'm so fond of the Yenona's. Their initial sound quality just knocked me out, not to mention they're easily the most comfortable headphones I ever used.
Thanks bro! I would have got myself a set already if I knew they were open. Cool, I will give them a try at that price. I signed up on the MO. Now just hoping the sound does not disappoint! =)
Im waiting for some ausdom m05 bluetooth headphones, just got them for the 33$ price. dont know anything about them. But i ordered 3 or 4 pairs of hm5 pads when they where on sale for 16.5$ and 5% off for next ones, so had to use them on something.
May just grab a pair myself. Since they are dual entry I'd cut that pleather headband off and go the old school skinny band I haven't had since the PX 95. Shave 10 or 15 grams off as well most likely
