reluctant_engineer
Glad you're liking them! Their bass is a bit loose and while I don't run into distortion at the volumes I listen (i.e. really low), I could see that becoming an issue as you up the volume dial. Still, they're quite fun Did you stick with the stock tips or have you played around with different options?
Surprisingly, the stock ones provided decent comfort and fit for me. Although I will start tip rolling eventually, to see how it affects the sound.
