Chinese / Asian Brand Info Thread (Headphones, IEMs, Amps, DACs)
Status
Not open for further replies.
May 27, 2015 at 11:45 PM Post #16,261 of 35,472
Singleton
No problem, I'm just kidding with you. Figured there were probably a good reason
All Good
May 28, 2015 at 12:38 AM Post #16,262 of 35,472
hakushondaimao
Calgary, AB
Anyone heard of, seen or listened to the Opera Consonance 32-384 DSD 128 Portable Music Player? Have started a thread on it that I'll be adding to over the next little while. Come on over and check it out if you're interested in a high-end Chinese DAP that can compete with the big boys!
Link: http://www.head-fi.org/t/769277/consonance-suzanne-32-384-dsd128-portable-music-player
May 28, 2015 at 12:48 PM Post #16,266 of 35,472
Zenbun
MD is dropping the Superlux HD668B again:
https://www.massdrop.com/buy/superlux-hd668b-headphones?utm_source=Sailthru&utm_medium=email&utm_term=Community%20-%20Style%20-%20MAU%20%28Active%29&utm_campaign=Men%27s%20Style%20A%20Product%20Announcement%202015-05-28&mode=guest_open&referer=5G5ALU
May 28, 2015 at 1:40 PM Post #16,268 of 35,472
Norway
The HI2050 sells for as low as $35 on Aliexpress. If you aren't treble sensitive, they are an amazing sounding and very comfortable headphone.
Ordered a pair yesterday :wink:
May 29, 2015 at 12:55 AM Post #16,270 of 35,472
Norway
Where did you ordeted it from ?
Aliexpress, seller: Digital product discount store
Will probably recieve them after the summer holiday :wink:
May 29, 2015 at 5:57 AM Post #16,271 of 35,472
Singleton
Do you agree with Ethan Winer's opinion in these two video's below?
May 29, 2015 at 12:39 PM Post #16,274 of 35,472
A bunch of old-farts with hearing aids talking about effects of after-market audio and digital cables, jitter, etc, right?  I think I seen this one before.  Every cable disbeliever I talked to always references Ethan Winter video and tells me "I don't need to try/test replacement cables, Ethan said so" lol!!!  Big mistake because you have to test it yourself before drawing this conclusion.
I don't discredit anybody's work or believes, we all entitled to our personal opinion and as I always say, there is no "right or wrong away about it".  We all have a different perception of sound, use different headphones, sources, audio files, etc.  I personally don't agree with some of their stuff because I tested a lot of headphones and can hear a difference between stock OFC and pure silver audio cables when listening to hi-res DSD audio files.  The same with digital usb cables, though I don't believe in $1k usb cables, I run a test with pure grain copper cables with silver outer core (check out my review of Audioquest cables, follow a link in my signature, scroll down through all my reviews toward the bottom) and I found $25-$35 AQ cables make a difference in comparison to $5 cheap generic usb cables.  Just using my ears and my head as the main tool to assess the difference without relying on someone else's opinion about
May 29, 2015 at 1:27 PM Post #16,275 of 35,472
bhazard
Cables are tricky. If the cable changes the source signal (impedance/resistance/whatever), yes you will hear a difference, no matter what price the cable is.
Once you get a strong enough core though, and imp/resistance matches, you won't hear a difference. I did the "coat hanger" test, where I used coat hangers to connect my speakers to my source, and A/Bed with a $200 cable with silver tips. No difference.
Status
