Chinese / Asian Brand IEM Info Thread
Jan 8, 2020 at 8:44 PM Post #29,552 of 33,689
Jan 8, 2020 at 10:11 PM Post #29,555 of 33,689
What do you want to know , pm me for deets
Isn't this basically the same design as the shuoer tape and very similar to their new model the shuoer singer? It basically looks like an electret with a DD.....
Jan 8, 2020 at 11:26 PM Post #29,557 of 33,689
I second this recommendation. These are the best foams I've used. Very little effect on the sound aside from taking a bit of zing out of the sibilant zone, and durable. Keep in mind they're a bit over-sized. I consider myself to have normal sized ears, and the mediums are almost too big (I use small).
They don't have opening on top
Jan 8, 2020 at 11:43 PM Post #29,559 of 33,689
I was totally confused when I first searched for these too! The names are very similar, and it seems that Flare's main business is earplugs. You have pictured the earplug replacement tips, which is all I could find when I first saw their IEM tips mentioned in another thread and went searching for them.
What is being recommended here are "Flares Earfoams Audiophile Tips" they also make another style of foam IEM tips and a style similar to the Audiophile foams in silicone.
Jan 9, 2020 at 1:34 AM Post #29,563 of 33,689
Thanks a lot, they offered free shipping and I made an order for small and medium.
Will post my finding when I get them.
Jan 10, 2020 at 6:32 AM Post #29,565 of 33,689
I noticed that the Jade Audio EA3 picked up a lot of noise from the wind and I have some thoughts about the reason why.
1. Because it protrudes from your ears a bit it is easier for the wind to "touch" it.
2. because it has a hole that allows airflow to flow in, angled at a perfect spot for wind to get in.
