The japanese manufactors have big tips whit 14mm. I see alot when i was looking on amazon japan where i got my aznas fromI'm like you..big ears. Been trying to find XL tips. Saw a amazon UK seller who suddenly adverises XL tips
6 Pairs - Black, Earphones Plus Brand Replacement XtraLarge
6 Pairs - Black, Earphones Plus Brand Replacement Ear Tips X Large
So I ordered some on Prime for tomorrow. Maybe they will genuinely be XL. I doubt it though.
Chinese / Asian Brand IEM Info Thread
- Thread starter Brooko
I saw somewhere a listening experience enchanting substances thread here on headfiWow .... should we have a pot thread now?
silverfishla
We should have a pot thread. As in...what’s the best music you’ve heard whilst being sky high.Wow .... should we have a pot thread now?
I was listening mainly tupac snoop and nate dogg when i was highWe should have a pot thread. As in...what’s the best music you’ve heard whilst being sky high.
BadReligionPunk
a couple of my favorite albums
One of the best albums of all times
NeonHD
Does it able to be used as a bluetooth DAC too?
Nope. This is an entry-level DAP released back in 2015 so.
DynamicEars
- Jan 5, 2019
For the record the **** pro isn't neutral. Definitely has a v shape.
It's my new favorite under $50.... Need to compare to my bqeyz bq3 but it's going to be close on sound (bq3 fits better). OOTB tuning is very good IMO.
Switching to acoustic music as I write this since I never heard the original ****.
Soundstage is exceptional, and not just "for the price". Bass is deep and has good texture. Could be a bit more forward....
Timbre is, a tiny bit off without EQ, but sounds fine tweaked. No EQ/MSEB it can sound a bit honky and a little too thick at times but that is really a minor nitpick that I have to really look for. It only takes minor adjustments to fix though....
Excellent pair, except I swear to God I'm getting a periodic shock on my ear where the metal is touching my skin.....
Damn, they still retain the shocking effect! I always literally get electrified with original ****
SciOC
Oh this is an actual thing? I just thought I was going more insane, literally.Damn, they still retain the shocking effect! I always literally get electrified with original ****
DynamicEars
- Jan 5, 2019
I thought my unit is defective one, but turned out that some of user also got shocked by them. And can't believe the Pro version also electrifies, they should've fix that!
DBaldock9
If an earphone uses MMCX, then the jack has to be isolated from the metal shell, if you want to eliminate the possibility of being shocked. One issue with putting the jack in a simple plastic bushing, is keeping it from pulling out when unplugging the cable. I've had a MMCX jack pull out of a PT15 earbud, so I'm extra careful with them now.
This is one place where the 2-Pin plugs have a natural advantage, since both pins are usually isolated from the earphone shell.
superuser1
I had the same issue with a whizzer a15 non proI thought my unit is defective one, but turned out that some of user also got shocked by them. And can't believe the Pro version also electrifies, they should've fix that!
DBaldock9
Also - Your cable needs to have insulated MMCX plugs!
SciOC
Well holy crap, I guess you learn something new every day. Thanks for the info, now that you mention it, the outer ring is obviously not insulated well enough from the metal shell.Also - Your cable needs to have insulated MMCX plugs!
Yayyy for not going crazy though.
LaughMoreDaily
BURN IN IS REAL! My Blon 01 sound great now. Wowzers. The best iem that will ever exist for $15USD.
How long did you burn in whit out listening ?BURN IN IS REAL! My Blon 01 sound great now. Wowzers. The best iem that will ever exist for $15USD.
Total: 22 (members: 0, guests: 22)
