Chinese / Asian Brand IEM Info Thread
post-15260959
Post #27,616 of 31,576
Jmop
I'm glad it worked for you. Even though the spacer fixes the slippery issue I still can't use this model (CP145-M) without getting the ear tip stuck in my ear when taking it off. :frowning2:
To me, it's either MH755 tips or Spiral Dots since they can "lock-in" on the nozzle.
Ah, I’m sorry to hear that. I don’t have that issue with the 145 on the Blon but the tips do get stuck sometimes depending on the earphone. They did on my Simgot Pros.
post-15260972
Post #27,617 of 31,576
Jmop
I purchased a re-cabled MH755 recently as well. It sounds cheaper than the Blon is the best way I can put it, but it’s also an easy recommend. It needs some power surprisingly, while the Blon is easier to drive.
post-15261068
Post #27,618 of 31,576
Sulbh
Hi can someone recommend an upgrage to soundmagic E10 in the samenprice range with same sound signature. If find them very good considering their price. Their soundstage and imaging is excellent. I am looking for something which can retain or exceed these traits.
post-15261337
Post #27,619 of 31,576
Coyro
Somewhere
Somewhere
This way the CP145 doesn’t slip further down the nozzle, giving the earphone more distance from the ear thus increasing comfort.
This is exactly my first solution for BL03. I changed the CP145 to Whirlwind later though.
Yes, the extender worsens the adhesion and CP145 core diameter is a bit wide for BL03. I had an extender longer than @Jmop and CP145 keep stuck in the ear or fly all over the room when I pull the unit out. :)
post-15261424
Post #27,620 of 31,576
yorosello
Dal
Dal
can anyone recommend me a good bluetooth module for tfz no. 3? maybe with APTX support or LDAC?
post-15261468
Post #27,621 of 31,576
Cevisi
Germany
Germany
You mean you want to buy a Radsone ES 100 why do you already dont got one
post-15261473
Post #27,622 of 31,576
yorosello
Dal
Dal
it's not available in my country, I mean something like the KZ's aptx HD 5.0 bluetooth cable or TRN one.
post-15261626
Post #27,623 of 31,576
Cevisi
Germany
Germany
These bluetooth cables will be a sound downgrade
Reactions: superuser1
post-15261818
Post #27,624 of 31,576
dharmasteve
London, England
London, England
The FiiO BTR3 is very good. It has LDAC which works very well. The FiiO BTR3 turns all your IEMs into bluetooth IEMs. Sound quality is excellent.
post-15261880
Post #27,625 of 31,576
yorosello
Dal
Dal
post-15261882
Post #27,626 of 31,576
yorosello
Dal
Dal
I would buy it if it was available here at the local store... And I see it's a bit expensive too at the moment. I guess I need to wait a bit
post-15261912
Post #27,627 of 31,576
Nimweth
Sussex, England
Sussex, England
Reactions: zachmal
post-15261927
Post #27,628 of 31,576
mbwilson111
post-15262136
Post #27,629 of 31,576
Otto Motor
Calgary, AB, Canada
Calgary, AB, Canada
Website
www.audioreviews.org
Hi can someone recommend an upgrage to soundmagic E10 in the samenprice range with same sound signature. If find then very good considering their price. Their soundstage and imagibg is excellent. I am looking for something in which can retain or exceed these traits.
The Soundmagic E10 is a pleasant chillout iem with absolutely nothing offensive and a slightly forward tilting, warm frequency profile. For chill out, I also use the iBasso IT01 (best bass I can think of; nice and airy stage, good speed...one step up from the E10) and the Blon BL-03 (tonal accuracy). I always get back to these...they feel like a treat every time...all dynamic drivers.
There are some much more expensive and technically more refined iems in my drawer...I still like these better.
post-15262170
Post #27,630 of 31,576
audio123
Reviewer at audio123
Users Who Are Viewing This Thread (Users: 7, Guests: 9)
