Slater
Needs some work. The best part of this design would be some surface area so you can have more than one button. One button and volume control is absent is not ideal when you have the surface area to do it. If BT 5.0 is more efficient I would also hope for more battery life from this design. We are getting 5 and 6 from TW with just the buds so surely this design could get closer to 10 hours than to 5 hours. Of course what about charging?? Does it come with a cable to charge both at the same time or you'd need two cables. I'd suppose it should come with a short cable that splits into 2 micro USB on one end to plug both into one USB port. And yes it is clunky to have to open the little flaps on both. Probably need to go back to the drawing board and design a more TW snap in design.
This would make a good case for them though that could charge both at the same time...https://www.amazon.com/Back-BayTM-D...qid=1541855914&sr=8-4&keywords=Back+Bay+Audio
Still will applaud the effort but hope to see the evolution of it.
On stuff like that, I usually tear off the rubber charge port cover because they’re a total headache to deal with. It’s on the bottom, so even if you get caught in a light rainstorm it’s not going to flood the port.
