Chinese / Asian Brand IEM Info Thread
94 95 96 97 98 99 100 101 102 103
105 106 107 108 109 110 111 112 113 114
  1. jant71
    Keep telling you they weren't fitting you right. The RT10 need some treble sparkle :) They are a bit rolled and smooth. You are in the minority like 7 to 1 of owners say they lack some treble brightness. They are difficult to fit right even if you think you might, you may not.
  2. TwinACStacks
    [​IMG] Personally, I'm not jumping on the trending "More is Better" BA driver Bandwagon. Even with the Noble 10's, although they are a Stellar definition and Soundstage Earphone, (Yes I have auditioned them), they simply LACK the Bass IMPACT, (I'm not certain of the word here), having all BA drivers that a B/A--D/D complement has. The BAs (to my ears) just lack that certain something, (Dynamics?[​IMG]), that is afforded by a larger dynamic Bass driver. Ultimate would be like 2 11mm Dynamics and 10 BA with Crossover networks. They might be too large to insert in your ears though....
    JMHO
    [​IMG][​IMG] TWIN
    romeyp likes this.
  3. Vidal
    Hi mate, I find the 4in1 at the top end of my treble acceptance but the RT-10 are a lot darker in comparison. Looking at Hisoundfi's review he said this about the treble: -
    "Treble
    Treble response does take a small step forward from the midrange, but is still on the more neutral side of things. It is a snappy and accurate treble with good PRaT. I think it’s in a really good spot to round out a very entertaining and non-fatiguing tuning that many will really appreciate."
    That mentioning of non-fatiguing seems to indicate he found the treble fairly relaxed as well, you must have had a defective pair. I know the Macaw use a carbon fibre diaphragm which Hisoundfi mentions was previously used in a pair of JVC's that he found too bright. Maybe your pair was missing a bit of gauze or something.
  4. TwinACStacks
    [​IMG] You may be right jant. I can only call my impressions as they worked for me. Remember, I also had trouble with another very popular Visonic earphone that everyone raves about but I heard as very Small and Tin-ish. I could NOT get them to fit.
    [​IMG][​IMG] TWIN
  5. Vidal
    Just in case anyone misses it my comment regarding the 8BA relates to the fact they have Man United on the side. A British football (soccer) team who has a rivalry with my own team. Old Trafford is a huge stadium but is famous for being a bit quiet  on match day unless United are playing well.
    TwinACStacks likes this.
  6. TwinACStacks
    [​IMG] Vidal, It could be also like jant said, I may not have been able to get them to Fit properly due to my personal ear anatomy. THIS is the main reason I prefer down-cable type of Earphones as I know I have a propensity for not getting the best fit from all universal Over-Ears.
    I also can't get Foam Eartips to work consistantly, and I have tried every technique possible for insertion.
    [​IMG][​IMG] TWIN
  7. jant71
    BTW, I recommend the Penon hybrid tips for the RT10 as they are a stupid picky phone for tips to get the best sound out of them. They are good tips regardless. I got the gray/orange and they are very nice tips.
  8. haiku
    BA´s are useful in a hearing aid imo, nothing more. Never heard anything that convinced me. The 8mm driver of the KZ ATE on the other hand pumps bass and subbass quite nicely! [​IMG]
  9. mochill
    Zst is awesome , powerful subbass with clear midrange and treble that is diffused
  10. trumpethead
    I agree although I think we are in the minority on that oinion so far, no pun intended...LOL
    mochill likes this.
  11. Vidal
    The only multi BA driver earphone I've used is the 1More Triple Drivers - I find these have too much bass for my liking normally and I EQ both the sub (slight) and mid (a lot) down.
  12. Deb1995
    Hello,
     I'm looking for an earphone under $30.....I listen to almost every genre( mostly Rock, Pop, R&B, Vocal...).......I love the sound signature of Ate, But I'm looking for something better like Warm & detailed......I was thinking of Tennmak pro or piano or SENFER 4in1 .....Which is the better? & has more bass?......Also, are there any other option which I can consider?.....Please help me to choose!
  13. d8n0g
    The senfers are awesome indeed! You said you'd like something a little warmer...the senders IMHO are a little sparkly but can be tamed by eq'ing. Haven't tried the tennmak
  14. Vidal
    I don't see the Pro as a significant step up from the ATE. The 4in1 is a significant step up 'but' as many have said they're a bit bright. I work in GBP so some of these maybe above the $30 but only just: -
    1. Senfer 4in1 (bright), DT2 (less bright, less bass) or UEs (balanced)
    2. Urbanfun (Balanced)
    3. BK50 (Warm + detailed)
    4. Tennmak Banjo (Bass)
    5. Audiosense AS20 (slightly v-shaped)
    6. Mannhas C190 (cheaper) - my favourite single dynamic driver (apart from the Tingo copy of a very expensive earphone)
  15. mashuto
    Those are hybrids though, 2 ba's and 1 dynamic, which would be for the bass. And I think he was referring specifically to multi ba only sets.
