CES 2017: MQA announces TIDAL Masters, and more
Mar 31, 2017 at 1:05 PM Post #646 of 702
I own a delightful Jotunheim which hits the spot when it comes to desktop control centre. Not looking to upgrade. I looked at Tidal a while ago and nearly purchased just based on the improvement I found with the tracks. So I am tempted by Tidal, for the increase in quality...BUT...I am not sure how the MQA part will fit in. Do I need to purchase something to unleash the unfolding of the tracks?
You will have to excuse my ignorance and I am trying to read up, but is there a way to spend the least amount of money so it can work with my Jot or does it not work like that?
Guidance would be most appreciated. I am still slowly just walking out of pure beginner so be gentle!
Thanks! :)
Mar 31, 2017 at 1:24 PM Post #647 of 702
Thanks! :)
Tidal will decode MQA 1x for you without any additional equipment so the Jotunheim will receive either a 24/88.2 or 24/96 stream. Higher levels of decoding are currently only possible with a MQA enabled DAC.
Mar 31, 2017 at 1:35 PM Post #648 of 702
Thanks! :)
The following is public service announcement:  RUN!
ORT
Mar 31, 2017 at 1:44 PM Post #649 of 702
Thanks! :)
I also use the Jotunheim with my PC and it works great with the TIDAL desktop application which allows you to listen to partially unfolded (24/96) hi res master tracks that are available through TIDAL. Nothing else you need to buy. If you had an MQA DAC you could get the fully unfolded master tracks (24/192) but I doubt you'd hear much difference the current albums available in master format already sound great.
Mar 31, 2017 at 10:45 PM Post #651 of 702
  I think I have a decent enough setup, and should be able to hear a difference in Tidal 1x unfolding. But so far I've only found a few examples of what seem to be albums of the same provenance, in both HiFi and MQA, and I cannot hear any difference between them. Maybe I just need to find the right albums? I have a nice little Schitt stack with a range of cans, IEMs, and speakers. I have looked at the Brooklyn DAC and other MQA boxes above and below that price point, but I need to be convinced it will be worth time and money.
It should not be so difficult to find tracks to compare. Mostly I've found MQA files processed from a higher-quality quality masters than the reproductions that were already on Tidal. Those are not useful comparisons. I do believe that I've found a few Jethro Tull albums that are a match: the Steve Wilson mixes in both HiFi and MQA. But although I hear a clear step-up in quality from older versions to the Wilson remixes, I hear no difference between the HiFi and MQA Wilsons.
Maybe jazz would be a better choice for my ears. The way Tidal is organized I can't easily find albums to compare, but even armed with the Google Sheet of MQA albums on Tidal, I'm not finding useful matches. For example, the Modern Jazz Quartet is listed as having albums in both formats, like European Concert Vols. 1 & 2, and Lonely Woman. But those are clearly of different provenance, with tracks of different lengths, and even different album art. This is getting tedious, and I have better things to do with my time.
Can anyone suggest albums for me to compare on Tidal? Albums you know are from the same source? Maybe some jazz? I know about the free downloads on the 2L Test Bench page, but for now this needs to all happen on Tidal here.
Check out James Taylor's album "Gorilla" - track Angry Blues. The regular HIFI sounds somewhat brasher,
messier, somewhat blurred - images are quite flat and indistinct in both shape and position within the sound field.
The Masters/MQA version is more natural, higher resolution-sounding, with
much more believable imaging, much better space and position within the recording...and it not only sounds
more detailed but sweeter/more natural,coherent,refined and is for me easier to enjoy.
To sum up, MQA sounds higher resolution, more natural and once appreciated makes
me seek out the MQA version against the regular FLAC. Well done conventional hires albums are (probably)
roughly about as musical to me as Tidal software-decoded MQA.
....this is pretty much my experience with most if not all of the Masters recordings that I've heard (again,
played through Tidal software-decoding, now in Audirvana Plus 3).
Apr 1, 2017 at 1:01 AM Post #652 of 702
What differences do you hear between TIDAL's software and Audirvana? Are there any functional improvements with Audirvana?
Apr 1, 2017 at 7:11 AM Post #653 of 702
I also use Audirvana 3 and love it to stream MQA albums with TIDAL. Audirvana to my ears offers a much more clear background and better resolution. Tidal alone sounds a bit muffled in comparaison. However, what I appreciate most with Audirvana 3 is that I can use the powerfull izotope upsampler on the fly and upsample the MQA files unfolded at 24/44, 24/88 or 24/96 up to 24/192 currently (old mac, so it does not support 24/384 but that is technically possible). In essence, it should be possible to replicate the second MQA unfolding done in hardware with the correct settings in Audirvana 3.
Apr 1, 2017 at 10:34 AM Post #654 of 702
hi there....when I discovered that TIdal no longer streams Yes Master albums - keeps loading
and never plays - but through Audirvana 3 Plus they play fine - plus the fact that I can use
my equalizer (AudioUnits/Voxengo Marvel eq) - and that it sounds as least as good as Tidal desktop -
maybe better - but with eq Audirvana is obviously better with my headphones - no eq possible through the current Tidal desktop.
With my setup, I find music sounds best without izotope upsampling.
The software set itself up seamlessly, with my Tidal logged in as well as all of the best settings
automatically set - I was beyond impressed. (I upgraded from the demo).
On a side note - I'm also greatly enjoying my portable setup with conventional hires files -
iPod Touch 6th gen with Kaisertone sw/USB3CCK/AQ Jitterbug//Mojo/SR325e. Properly eq'd to
subdue the highs - very slight subtle drop from 4k to 20k- I find that the 325e's sound amazing -
supremely musical and not far off from my GS1000i's.
Apr 1, 2017 at 3:29 PM Post #655 of 702
maybe better - but [COLOR=000080]with eq[/COLOR] Audirvana is [COLOR=4B0082]obviously[/COLOR] better with my headphones - no eq possible through the current Tidal desktop.
On a side note - I'm also [COLOR=800000]greatly[/COLOR] enjoying my portable setup with conventional hires files -
What do you mean with "...when I discovered that TIdal no longer streams Yes Master" ?
Apr 1, 2017 at 4:00 PM Post #656 of 702
Master albums by the classic all-time prog group "Yes" (non-Masters play fine):
http://www.allmusic.com/artist/yes-mn0000685647/discography
Apr 1, 2017 at 9:12 PM Post #658 of 702
Strange. Yes Masters work for me. I tired 90125 and Big Generator and both played just fine in the desktop app.
Sent from my ONEPLUS A3000 using Tapatalk
The Masters albums in questions are Close to the Edge, The Yes Album, Fragile and Relayer - four of
their very best albums
Apr 1, 2017 at 9:53 PM Post #660 of 702
@headfry I tried all four albums you mentioned. All four Master versions play fine on my desktop app running on Windows 10.
My setup: ASUS laptop, Meridian Explorer² USB DAC, WireWorld Ultraviolet USB cable, Sonus faber PRYMA headphones.
