Dexter Morgan
- Feb 23, 2007
Maybe there was just a bad batch? Can't imagine they didn't test it with the 6+ before going into mass production. Does anyone on here have a 6+ that fits?
What color is your case?
Curious if the colors have slightly different shape.
Fitting issue could be due to protruding camera from 6+
Little DIY should fix the issue(scraping the camera window)
As the device sounds great, I feel that Centrance should not be persecuted( If fitting issue can be fixed by DIY)
There are so many waiting patiently for 6 skyn( I feel for them, I changed from 6 to iPod touch version)
Very happy with sound and build.
About charging, Skyn will not charge iPhone until it is fully charged, then it charges pretty fast
Hopefully everyone will be happy at the end( Centrance did not manage this well but they are working hard, really hard)
Thats my take for now though I was very frustrated with long wait
Persecuted? No, but I don't think it's too much to ask for the product to fit the iPhone without breaking out the dremel or a filer, if that will indeed even fix the issue.
I hope I don't end up with an ill-fitting Skyn.
[color=rgb(34, 34, 34)] [b]Music Boost specs:[/b][/color]
[color=rgb(34, 34, 34)] Headphone Impedance / Output Power[/color]
16 Ohm 44 + 44mW
32 Ohm 22 + 22mW
64 Ohm 11.5 + 11.5mW
300 Ohm 2.5 + 2.5mW
I believe the Skyn has way more power than the Arcam,
Code:[color=rgb(34,34,34)] [b]Music Boost specs:[/b] [/color]
Code:[color=rgb(34,34,34)] Headphone Impedance / Output Power [/color]
Code:16 Ohm 44 + 44mW
Code:32 Ohm 22 + 22mW
Code:64 Ohm 11.5 + 11.5mW
Code:300 Ohm 2.5 + 2.5mW
That is indeed not a lot. Good enough for some iems but far from great. Skÿn destroys these specs....
Yep according to the initial specs for Amp Extreme, the IGG site says it will do 300mw per channel into 32ohms...
