do you think ca16 are siutable for dance and techno [blank an jones - desire]? there is enough of bass? or better work do zsx?
I personally am not a frequent EDM listener (though I appreciate it), but I just listened to Blank & Jones - Desire, both the single and its ambient remix, and made a quick comparison between the CCA CA16, the CCA C12 (that is the closest I have to the ZSX) and the TRN V90 for good measure.
Out of the 3 the V90 has the most bass (a good bass with a nice rumble) and will probably be the best bass experience in terms of EDM, though there is less detail in the synths (thinner mids and treble). The C12 (also the ZSX) has both a nice rumble and some extra meat on the synths and voices - probably the best compromise. The ZSX has a tad more bass than the C12 by the way, though it is more of a one note affair.
The CA16 in isolation has more than enough rumble and bass, though it is not a bass-head earphone, and to my ears has the most textured bass of the 3, but it is lower in quantity (not neutral, not shy, just more balanced). The synths however have an amazing texture and authority! On the ambient mix of desire, the pad synths are just intoxicating with the CA16, so juicy!
If EDM is your main genre and you don't mind losing some detail and balance to get a more exciting experience, then the TRN V90 might be for you. The ZSX or C12 will be the ideal compromise, there is no going wrong there (just know that the ZSX isn't great with brass instruments). The CA16 is still my pick though, for the detail, timbre and balance.
