Cayin N6ii, Unlimited Possibilities: a fully modularized smart DAP
- Thread starter Andykong
mwhals
- Jul 26, 2015
The review makes the N6ii and LP6K sound best for me instead of the LP6K vs LPGT.
I miss the cowon PL in the comparisons
- Oct 6, 2013
PL battery is fully drained, will have to charge it up and update the fw; sorry, haven't used it in a while...
Sold mine meanwhile , but know the sound .. same dac and so on ... would be interesting but otherwise nice review as alwaysPL battery is fully drained, will have to charge it up and update the fw; sorry, haven't used it in a while...
Great review, shouldn’t have read it. Now I want to demo it after hearing your M5 thoughts with the combo.
- Oct 6, 2013
Are you coming to CanJam NYC? Would be a great opportunity to test everything since I believe Musicteck will have it at their table.
Btw, a real secret sauce to make the best of M5 (if you have universals) are the new Symbio orange foam eartips. Not sure if they are for sale yet, probably soon. These new all foam tips make universal M5 sound like custom without the usual "foam" sound artifacts.
- Oct 6, 2013
The same DAC, true, but Class A/AB discrete amp section what's going to make N6ii/E01 stand out.
- Sep 27, 2011
The antivirus alert probably was caused by the http protocol instead of https in our download page. See if you can download form Google Drive directly:
https://drive.google.com/open?id=1oVsCof-MHUpksvWRVC8Exc9Uz1uSWQnn
Will repair the missing download button after Chinese New Year holiday.
Regards,
Andy Kong
@Andykong -
Hey, is the security certificate for this device going to be updated? It’s from 2017 if I recall correctly.
- Sep 27, 2011
Any chance for a comparison of the Colorfly U6 with the N6ii, Lotoo 6000? : )
nope unfortunately I can’t go to canjam NYC. I have the custom M5, i did love the regular symbio w’s with the universal ones but i find the custom M5’s signature to be quite similar to that pair.
Nice review as always... keep up the good work...
Hope you have AMP8EX-FE to compare...
Low volume listening on E01... that what keep me interested ....
Thanks for the review Twister6.
I agree with your findings for class A vs class AB too, I happened to be listening to Massive Attack's Risingson from the Mezzanine album while I was reading I checked and yes you are right.
I don't usually do these types of comparisons because I don't have the audio memory between swapping setups but the swap from A-AB and back again is so quick that its like a night and day change.
Hi all, I've been using my new N6ii for about a week, so far so good but I notice the WiFi reception is weaker than in my phone and laptop... is that normal???
I can't even use it for streaming in one of my work locations, but I'm able to use tidal from my phone and Laptop in the same location.
Also sometimes it suddenly stops playing when streaming...
Thanks
Thanks
Thanks
I also have the same issue, and it's frustrating. Can this be fixed with a firmware update? Overall I am extremely pleased with the N6ii, but those little WiFi dropouts are annoying.
Total: 8 (members: 0, guests: 8)
