- May 7, 2017
yes
as I read from one russian review it is a little bit more neutral, crisper, brighter etc
Some say T01 sounds almost the same as A01 which is already good.
yes
Can you give an idea of how the sound of T01 differs to A01? i.e. is it more neutral, crisper, brighter etc
May be a stupid question, did anybody try HD800s with n6II form the 4.4 output?
It is obvious that these cans need a higher grade/level of amplification, just wondering if it make sense to try while waiting for a good amplifier.
Thanks.
YES, it sound good, love the synergy.May be a stupid question, did anybody try HD800s with n6II from the 4.4 output?
It is obvious that these cans need a higher grade/level of amplification, just wondering if it makes sense to try while waiting for a good amplifier.
Thanks.
I haven’t, but when I get home I will. I did run the ZMF Verite and ZMF Verite Closed, along with the ZMF Aeolus with the N6ii and all worked very well. They are all in the same power requirements ball park as the HD800 so I am confident the N6ii will power the HD800 just fine from the 4.4mm.May be a stupid question, did anybody try HD800s with n6II from the 4.4 output?
Thanks.
If you getting nervous then you not ready.Was about to pull the trigger on this until I read that people were experiencing interference issues running out of balanced with Wi-Fi on. Is this something that affects only some units (or modules) or is it all? Would anyone be able to comment if they hear anything when using Tidal with IER-Z1R from 4.4 in particular? Thanks.
I have the Andromeda Golds, and Andro v2 (I think?) and with 4.4 I get some noise but less with the golds. But the Andromeda’s are notoriously sensitive, I haven’t had any issue with noise with any of my other headphones so far using 4.4mm...but I do use a 4.4mm to XLR adapter for everything that isn’t the Andros, not sure that makes a difference “I’m a consumer Jim, not a scientist!”I can pick up interference on Andromeda 4.4 output with Tidal streaming but not with full size Aeolus headphones. So I suspect it comes down to sensitivity.
Will hopefully be picking up ier z1r this weekend so will give it a try to see if I hear anything - I'm hoping not.
Andros are blah.I was thinking about picking up a 4.4 cable for the Andromeda golds (or maybe the dunu hulk), but I already hear some slight hiss with the gold's on the 3.5 output so I imagine there would likely be more on the 4.4 with the n6ii, but if that's not the case...
